My 19" Trinitron has a maximum resolution of 1600 x 1200 @ 75Hz.
The 21" Trinitron I mentioned above has a maximum resolution of 2048x1536 @ 80 Hz, and a recommended resolution of 1880 x 1440 @ 85 Hz
Cool.
Twas a sad day when my 21" Nokia monitor died - Trinitron tube.Gawd, I agree with that. I HATE giving up my Trinitron CRT.
going from a good CRT to any LCD suuuucks.
if youre going to say you can only compare to the best crt's that were available, then you have to compare them to the best lcd's out right now and thats going to be a competition.
Indeed it does..
But most people didn't have the better CRT's.. what sucks most is the bigger tube CRT's, like the Sony 34" that did 1080p and such.. had some serious reliability issues, and many were dead in two years.
There's a huge difference between these two types of CRT's:
So don't confuse your standard as-can-be 90's PC monitor with your higher end, flat screened Sony Trinitron. Tremendous differences in image quality.
I'd kill to get my hands on something like that today :wub:
I definitely agree that there's a huge difference between cheap CRT monitors and quality CRT monitors.....
I came about -> <- close to driving down and at least looking at one of these:
http://www.keithmay.org/equipment/Sony_CPD-G520/Sony_CPD-G520_Spec_sheet.pdf
IF it's in good working order, it's definitely worth the $30 he's asking for it...BUT, when I factor in the cost of gas in the Expedition to go look at it...(about 125 miles each way) that kind of takes the shine off of the deal.
Indeed it does..
No. I had a G420, and it was unusable at 1600x1200 75hz. I had to go all the way down to 1280x960 for a sharp image. My dad uses it now, still at 1280x960, which is good for him.
I think you guys talking about how CRTs are better in every way must have cataracts or something!
Agreed.
I was apprehensive too when I upgraded to my first LCD (PVA-panel Dell 2709W) but, once I got used to the chiefly larger screen, higher resolution and wide-screen AR, I never looked back. The extra desk space (depth) was also appreciated.
I kept the Sony mainly for nostalgic reasons and because it was still working fine. I'm thankful too for its image restoration feature which helps maintain its screen brightness.
I never had any option for VGA cable with my 420GS...it came "built-in" to the monitor, and it's close to 1/2" in diameter.![]()
You can find it somewhere in the Color settings. It can only be used when the monitor determines it has been warmed up enough (which can oddly take a while, somewhere between 10-20 minutes).Image restoration?
They were probably those average ass CRT's though.. with the curvy screen that bubbled.
I had an old flat screened Sony 19" Trinitron that died on me years ago and I still miss the hell out of it. It was the best looking monitor I owned.
The nicer and higher end tube CRT's are some of the finest displays known to man. Anyone who had the opportunity to get a 34" Sony Trinitron with 1080p were the luckiest people on this planet.. because it was only produced for a very brief period of time. I've never seen a better display in my life. Absolutely jaw dropping picture. Weighs 250 pounds though.
LCD's mainly pushed out CRT's because they were cheaper to manufacture and ship, not because they are superior technology.
In other words there really is no such thing as a shitty LCD [...]
Agreed.
Oh, there is a such a thing a shitty LCD, they're pretty much standard issue on cheap laptops.
As for the issue of text clairity on CRTs, one thing to watch out for is ClearType and other text anti-aliasing systems that assume you're using an LCD. It ends up looking awful on CRTs or if you haven't configured it match the pixel layout of your LCD screen.
That's a F series, tons better than your G420. I wasn't impressed with a G series 19" either but a .22 mm constant pitch F series over shielded BNC at 1600x1200@85 is like looking at a photograph.
Your problem was a limp crappy unshielded VGA cable, I guarantee it. Keep in mind most peoples experience with CRT to LCD also coincides with the transition from analog dsub to digital dvi, and the cable contributes ALOT when running high resolutions over analog, where digital is unaffected.
At those resolutions over analog you absolutely must use individually shielded 75ohm coax cable cores. The blurriness you described is caused by capacitive coupling within the cable itself smudging the image at high frequencies. The resolution threshold you experienced between sharp and blurry is exactly where it typically occurs, going past 1024 and 1280 resolutions and higher refresh rates.
Most people in addition to having a cheap dollar store CRT also used a VGA cable the same diameter as their mouse cord, so they can't really objectively compare their CRT experience with LCD.
And you know what? It actually still applies, though to a lesser degree. I've seen a few folks hooking up their PCs or Laptops to extra monitors using VGA output, and the difference between a cheap cable and a good cable can make a giant difference even to an LCD or flat-panel TV. Obviously with those devices you want HDMI, DVI, or DisplayPort if they are available, but if you have to use VGA, then you want a GOOD cable.
I remember having 5 or so (maybe 6??) well insulated BNC twist-on Coax cables to hook up some of my larger CRTs, and the result was stunning. The cable was extremely heavy and not that flexible, and cost nearly half as much as the video card that I bought with it at the time, some Matrox Millennium card or other.
