I really think its the fact that bald men get more sun on their heads. Sun is very healthy for your entire body. I think going out and being active really curtails the dandruff problem. Just personal experience though. I have a bit of a problem in the winter but if I go out and just f!ck around a bit every day it seems fine.Originally posted by: Citrix
why dont bald men get dandruff?
:QOriginally posted by: dandruff
Originally posted by: PingSpike
Originally posted by: Brackis
Originally posted by: shenaniganz
Originally posted by: FoBoT
http://www.reviewcentre.com/reviews4993.html
Neutrogena T-Gel Shampoo Product Details*
Features:
# Controls the symptoms of psoriasis and seborrheic dermatitis
# Reduces hyperkeratotic build-up (scaling and crusting)
# Provides added conditioning
# With neutar solubilized coal extract
That stuff stinks, but it works.
I actually have used some sample sized bottle of this (smells like shoe polish?) and it didn't seem to help![]()
I had to use my stuff for awhile before it really started to work. I only bought it because they were out of the regular kind.
Features:
can you use regular shampoo right after using it to get rid of the smell? I always get dandruff in the winter time also.
Originally posted by: NogginBoink
If all else fails, see a dermatologist and get advice from someone more knowledgeable than a bunch of anonymous internet teenagers.![]()
Originally posted by: Sheepathon
rub lotion on head![]()
Originally posted by: Gobadgrs
have you seen a dematologist? You also need to make sure that you are drinking enough water. That should help with the dryness.
