Originally posted by: tfinch2
Originally posted by: Shawn
Originally posted by: DaWhim
I missed my A because I got 179.4 points on a 200 points scale. I am closer to my A than you.
doesn't that round up?
I know some professors that don't even round. 90 and up is an A. 89.9 is not an A.
I got an 83. I needed an 84 on the final to get an A in the class. My final grade is an 89.4%. FVCK!!!!!!
I just sent my professor an e-mail telling him that I had 3 finals on the same day and that that was my lowest grade yet. I usually do better on the tests. I went to every single class and even did most of the extra credit opportunities. Hopefully he'll show mercy and bump me up 0.1%. 🙁
Dear Shawn,
You ended up with 447 points.
I didn't take roll, so I don't know of your attendance officially,
but if you say you came to every class, then that counts for
something & I will trust you. I found two fill in the blanks
where you could earn a partial credit of 1 pt each, which
would bring your grade to 449. That's still technically
a B on the 500 point system outlined in the syllabus.
In these cases (which are B's that would round up
to an A using a 2 significant digit system), I can
assign an A-.
I will do that for you based on your good attendance record.
H Bass
My teacher replied:
Dear Shawn,
assign an A-.
H Bass
YAY! 😀
Originally posted by: Mwilding
Does it feel good to get something you did not earn?
:roll: right back at you. You didn't score the required number of points for an A and got it by doing the academic equivalent of crying to mommy. It's not like you objected to a subjective grading of a paper or claimed points you weren't awarded in error...Originally posted by: Shawn
:roll:
:roll:
:roll:
:roll:
I've had that happen to me, I needed 85 for an A but had 84.8 basically the prof said "An A is 85, if I rounded you up an A would be 84.5 not 85, sorry."
since when is telling the professor that you went to every class an extenuating circumstance?Originally posted by: MrChad
:roll:
He didn't deceive the professor in order to get a higher grade either. Professors often curve grades based on extenuating circumstances; I don't see how this situation is any different.
The extenuating circumstance was the scheduling of multiple exams on the same day.
If he lied about his attendance, then his actions were reprehensible. If he told the truth, however, then the onus is on the professor to adjust his grade or leave it as is. I don't see how this is any different from any other discretionary adjustments such as curves.
