Damn, It's Cold Outside!
FeuerFrei
9,144
929
He probably meant that it won't reach up to freezing. ;)
Yes thanks, that's what I meant.
That's hardcore for Texas. :( I feel sorry for my car with 10w30 oil. Maybe all the friction will warm it up quicker ... ?
Rhezuss
4,118
34
Lol you think it's cold...
We had 3 straight days of -38 to -42 with windchill in late decembre and early january.
Not fun sir, not fun at all...
lozina
11,711
8
It was really cold past few days then suddenly today it was in low 50's.
When I got in my car this morning it felt like I walked into a fridge as my car was still cold from yesterday while the ambient air temp outside was 50.
Rhezuss
4,118
34
Try moving? :p
Hahah nah, it's only between 3 and 7 days per year so no biggy. It's just when you plan to go outside and BAM you get hit by a chill wall of coldness +14...
And then your eyes are stuck in their holes...
rudeguy
47,351
14
61
OK this is nuts.
I got stuck at an intersection on the way home. No incline, no snow ruts, looked fine. But when I hit the gas, my tires just spun. I was on 100% ice and had no idea.
Funny thing is there was a big ass plow truck right next to me that had the same problem. We both sat there spinning and sliding sideways for at least 60 seconds before either of us got traction.
raasco
2,638
OK this is nuts.
I made it from the U.P. to East Lansing a couple hours ago. I like the snow banks. It feels more like home here now.
xanis
17,571
8
Going to be a balmy 11F tomorrow with a wind chill of -12. :thumbsup:
Not as bad as some of you Canucks, but it's cold for here. :p
rudeguy
47,351
14
61
anything below freezing is cold. It doesn't matter how far below that you go, its just more cold.
We didn't have a temperature most of the day today. Just didn't have one...
alzan
3,860
It's 1F here in St. Louis with wind chills around -25F. That wind just sucks the heat out of the house.
Our furnace is keeping up but just barely.
davmat787
5,512
24
Temperate Marine climate FTW.
Feel sorry for you guys dealing with the extreme cold and ice. Often people are immediately turned off by the rain in the Pacific NW, but then we don't deal with the humidity, 100+ degree summers, and the extreme cold and snow other parts of the country do.
I guess it all comes down to what you are used to and equipped to deal with. Personally I will take the gray misty winter days over what the Midwest and Northeast deal with.
Good luck to you guys, stay safe.
rudeguy
47,351
14
61
Yea it's not fun but I'm used to it. Knowing how to dive is the biggest thing. The cold isn't really an issue since you are only out in it for a minute or two at a time.
I feel worse for our southern friends when they get it.
mmntech
17,501
12
It's snowing like crazy outside. My new schedule has me working until 10:30pm. Roads are treacherous so I'm debating whether or not I should get a hotel. It's also bloody cold and windy.
Fingolfin269
17,948
34
Fucking hell, pipe burst on the irrigation... AT THE CUT OFF. The cut off valve literally pulled right off the pipe (along with part of the pipe). So I had to go turn off the water at the main to stop the flow. No water until we can get it fixed which should be tomorrow afternoon.
Not used to this cold so a couple of what should be common sense questions that I want to ask just for reassurance...
1) If I have water turned off at the main and there is no water flowing to any of the sinks then I should not have to worry about any other pipes freezing at this point. Correct?
2) This pipe burst at the cut off just below the back flow of the irrigation and this is where all of the excess water was flowing out. I assume this means the house is ok. Good assumption?
3) I've never dealt with this kind of madness before so not sure if there is another question I should be asking...
FYI, the reason we noticed there was an issue was because water pressure suddenly dropped. Should be unlikely that house pipes freeze here so I was doing a walk around the house to ensure all of the crawl space vents were closed. That's when I walked in a puddle.
F'n polar vortex! :p
13,805
Ouch, guess those pipes are on the cold side of the house? I would get that addressed. Lucky you did not end up with a huge mess. Someone I know here was not as lucky, pipe burst in their basement and it flooded the whole basement. That's my worst fear. I can do electrical with my eyes closed, but plumbing always makes me nervous.
With water turned off at the main, you still want to clear any other lines or any residual water could still freeze, though it wont be under pressure so it may be able to push somewhere assuming you opened a faucet to depressurize it. Though I'd open ALL faucets to try to get it drained as much as possible. Faucets upstairs and faucets in the basement. Upstairs ones will act as a vent and downstairs ones will drain.
Also make sure the cut off is still well protected and kept warm, if it bursts BEFORE the cut off, you are very very very very very screwed.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Because I'm not familiar with your plumbing I can't answer all of that, but what I can tell you is that:
-Water expands when frozen
-If it has nowhere to go when it expands it will make its own relief (as you found out)
While unlikely now, you can still have full water pipes. It's good practice to leave a faucet cracked (dripping) in severe cold if said plumbing is connected to a pipe that can freeze (like an exposed back flow valve) so the pressure has somewhere to go.
Do you not have a faucet or anything on your backflow assembly? After closing the cutoff valve, we winterize our irrigation and then keep a faucet cracked going to the backflow assembly. We have a faucet inside, directly after the cutoff valve.
Fingolfin269
17,948
34
Yeah the irrigation was supposedly winterized. The landscaper was honestly shocked this happened when I talked to him on the phone earlier.
We did have open valves around the house on the faucets so not sure what happened here or why it happened. He's going to have to figure that out tomorrow when he comes out here to fix it with his plumber. I have absolutely no experience with this at all as temps this cold are extremely rare here. So at this point all I know to do after shutting that water off is to open all the faucets and let as much water run out as will come out. At this point nothing is flowing.
feralkid
16,860
4,972
It's a good skill to acquire.
