cybrsage
- Nov 17, 2011
- 13,021
- 0
- 0
Just because you pretend to be correct does not magically make you correct - or did your magic man whisper into your ear that you are correct so you have no choice but to believe him?Not to the universe, but to eachother.
Tell that to the string theorists.
Time and space are a coordinate system. It is a mistake to think that the universe's existence requires them, or that you can infer the non-existence of the universe from the absence of 4 particular coordinate dimensions.
That's two strikes. Wanna take a third swing?
http://www.ugcs.caltech.edu/~yukimoon/BigBang/BigBang.htmThe big bang is not like an explosion of matter in otherwise empty space; rather, space itself began with the big bang and carried matter with it as it expanded. Physicists think that even time began with the big bang.
Why Do We Think the Big Bang Happened?
Three main observational results over the past century led astronomers to become certain that the universe began with the big bang.
The magic man made you forget all about it, eh? You can do a forum search for yourself and magic man. You will find it goes the entire way back to the point the threads vanish from the forum due to age/number. You and this magic man go way back. You brought him into being when you tried to say that the universe does not actually exist and that the posts on the forum are not real and that is why you were able to say you answered questions you clearly did not answer. If the universe does not exist neither do the questions posed inside the universe.I never said anything resembling that. You are lying.
Pretty nutty.
