The thing with blackcoin (and many other smaller coins & pumping) is that the amounts for sale and buy orders are tiny. 20 BTC could wreak havoc on the price (up or down) immediately.
And have more garbagecoins? No thanks.It could start a new craze in altcoins that follow the BC model, which would put and actually probably kill off most if not all of the coingen PoW clones. If this is the natural order of things, so be it!
I have not seen a whole lot of Coingen PoW coins to be honest.
The number of coins using Scrypt N is increasing which is nice to see.
No I don't have CCC installed on that comp, just the driver.
Try Sapphire TRIXX, it let me unlock volt on one of my AMD cards.
Or MSI afterburner. I've used Afterburner to successfully under-volt both my 7870s.
Probably still going to get around to bios flashing at some point just so I don't have to re-apply at startup.
Yep true, that is quite annoying. But if you check the option to apply profile at startup and have afterburner launch on startup, then you can get around that. I never turn off my PCs so I don't care much for it. Was much easier than BIOS flashing, that's for sure.
BIOS flashing is actually very easy and apparently you can do it right from windows too. (Maybe to the cards which aren't running the display)
I would HIGHLY recommend NOT doing it from within Windows. You run a much higher risk of bricking your cards if you do that.
Especially because it takes < 5 minutes to create a bootable USB flash drive that boots into DOS and allows you to use atiflash to safely flash the BIOS.
What would the purpose be for flashing the 290's? If for voltage settings have you found a bios editor for Hawaii that allows voltage adjustments?
Stilt has volt modded bios, but those are hit and miss and only work on reference 290/290x.
How does the most profitable Scrypt-N multipool compare to, say, ScryptGuild from a profitability perspective?
If your pool rejects stales (as it should) then startup with --no-submit-stale to avoid some of those rejects. Mostly matters on coins with fast block times.
