- Jun 10, 2004
- 14,608
- 6,094
- 136
Thermaltake is good. I in fact have a TW2-430 in my main rig that is roughly 8 years old. That system is always on. I used to mine with it. Same PSU.
I got the Coolmax from a combo I bought. I actually ended up replacing it on that system and just had it laying around. Regardless, both PSUs are fine.... The power cord actually melted on the Thermaltake, but I am currently using the Coolmax.
Both are just brand names and logos. The real maker of the PSU and what components they use determines the quality of the PSUs... and Thermaltake and Coolmax aren't known for being quality...
That said, if your PSUs check out there is something majorly wrong with your motherboard or you've got a massive short circuit somewhere. Those voltages are all sagging horribly. You need to make sure you're not running those systems while you're away until you figure it out, because they could very well burn your house down.
