Cryptocoin Mining?
Page 281 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
geokilla
2,012
Doge.netcodepool.org is down. Same with luckyminer. Such luck. Wow.
Use the 'validate' option under cgwatcher settings to validate your conf file.. You might have some mismatched tags
Says it's valid. Went out for an hour. Come home to see it stopped mining. Ugh...
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
I will continue to 'attempt' to figure out how to set up a pool server.
Word of caution though: A mining pool only works if people use it. If only a handful mine on it, it'll be as useful as one of the ones that are down.
CurrentlyPissed
660
10
Update:
Your miners are fine and your shares are being counted, just the website UI is down.
https://bitcointalk.org/index.php?topic=361813.2900
Another quick note to our Doge NetcodePool miners:
The front-end is being worked on.
The back-end which has the pool is working just fine.
Always remember that our front-end is completely abstracted from the back-end which contains our pool, so just because the front-end may not be available does not indicate at all the status of the seperate back-end pool part.
Keep those miners pointed to us! Your work is being recorded as normal and you will get paid out as usual.
https://bitcointalk.org/index.php?topic=361813.2880
Erenhardt
3,251
105
101
The only thing that it needs after that is moar exchange places.
Then much money to be had. Such wallet, most stuffed. WOW
Attic
4,282
The irony. I go ahead and spend cash on about 2.5Mhash/s worth of compute, only to watch the virtual currency economy get rocked.
Hopefully this is a good thing? Maybe all of a sudden people will flee for a while and difficulties will drop, meaning MOAR FOR MEEEEEE!!!! Then there will be another huge bubble and it'll be my turn to get rich on imaginary money!
Or I'll just be sitting on a pile of electronics that generate heat and take electricity and make pretty numbers on the screen for a while. Who knows! It'll be fun either way.
There are many folks racing to put together 10Mh/s+ setups to try and cash in on crypto currency mining.
I'm not sure if it means we will get a lot more traction with marketplaces who take crypto currency for purchases or if the rush (largest i've seen yet) for hardware to mine is a sign of the collapse.
It's certain that there is real possibilities for BTC to trade back to $20 per coin in a short period. It could also go much higher than 1k. This should be an interesting week, I think if Fed stays with no taper that BTC will rally. A taper would be bad for BTC IMO.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
I personally think that if the world had a public marketplace like eBay (NOT silk road... but with more commercially traded goods) that took virtual currency, that's all it would take.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Apparently doge difficulty broke 100 today... the LTC camp is wholesale shifting to doge in a big way for some strange reason.
much mining.
very wow.
geokilla
2,012
Has anyone got their payout from doge.luckyminers.com? I still haven't got my payout yet.
geokilla
2,012
doge.netcodepool.org is taking forever to accept shares now... I just went from 17s to 3 min per share. Still have a high hash rate of around 250 though (using comp atm).
Remobz
2,564
37
If anyone is keeping track of exchange rates and whatnot, apparently GalaxyCoin "Looks" like it's on fire right now... but apparently it's not. It's dead. The dev has announced he is no longer supporting the coin as of yesterday, the wallet is broken, there are no peer nodes or pools, nearly every block being mined (if you can mine it) currently is orphaned. Stick a fork in it, she's dead.
I hope this fad dies and goes away for good!
mkrohn
219
middlecoin is on DOGE and is about to have to cash out an insane amount... set buy orders up super low and just sit/wait
Gloomy
1,469
21
Wait, I thought Doge was a joke? I mined for like an hour last tuesday and made a quarter of a million. It seemed ridiculous so I stopped. Now diff is over a hundred and it's taking off?
I've missed another train. :thumbsdown:
Torn Mind
12,078
2,772
Coins are coins. If people want them, they'll buy them and the exchange rate goes up.
One MegaDOGE goes for quite a bit, but it has decreased since Bitcoin's worth in USD has been tumbling recently and hence one megaDOGE is worth less than it was a day or two ago.
geokilla
2,012
Does anyone know how to fix this? My share acceptance is really low. None of it is getting rejected though.
mkrohn
219
I dont see a problem with that at all... are you just not seeing much come acrss? could just be higher difficulty blocks being sent to you
KlokWyze
4,451
9
www.dogsonacid.com
yupyup.
Man. BTC is really falling, tempted to actually buy some, especially if it falls lower.
