geokilla
- Oct 14, 2006
- 2,012
- 3
- 81
So my rig died AGAIN last night. WTF. Here's the log:
Code:
[16/12/2013 1:52:38 AM] The computer is no longer idle.
[16/12/2013 1:52:38 AM] Computer is no longer idle, returning GPU intensities to their original values...
[16/12/2013 1:52:38 AM] GPU0 (AMD Radeon HD 7900 Series) intensity changed from 19 to 15 because the computer is no longer idle
[16/12/2013 1:52:38 AM] GPU0 (AMD Radeon HD 7900 Series) restore intensity to 15 after idle returned: I (GPU 0 set new intensity to 15)
[16/12/2013 1:54:51 AM] [d] Coins.Refresh complete, 51 coin(s) present.
[16/12/2013 1:56:38 AM] The computer is now idle (4 min, 22 sec since last activity, 4 min requirement).
[16/12/2013 1:56:38 AM] Computer has been idle for 4 min, 22 sec, setting GPU intensities to 19...
[16/12/2013 1:56:38 AM] GPU0 (AMD Radeon HD 7900 Series) intensity changed from 15 to 19 because the computer has been idle for 0 second
[16/12/2013 1:56:38 AM] GPU0 (AMD Radeon HD 7900 Series) adjust intensity to 15 on idle returned: I (GPU 0 set new intensity to 19)
[16/12/2013 2:01:38 AM] Accepted shares have not changed for 3 minutes, longer than the threshold of 3 minutes. Attempting to restart...
[16/12/2013 2:01:38 AM] [d] Miner.Restart begin.
[16/12/2013 2:01:38 AM] Because the miner is set to a .BAT file, I will attempt to stop and then start the miner so the .BAT is reloaded...
[16/12/2013 2:01:38 AM] [d] Miner.PerformStopStartRestart called. (Profile=NetcodeDogePool;Miner=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\NetcodeDodgePool.bat;HasFullAPIAccess=True;Initiator=Monitor;Reason=#NAME# was successfully restarted.)
[16/12/2013 2:01:38 AM] [d] Miner.StopMining called: Miner=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\NetcodeDodgePool.bat;ProcessID=4928 (True);BatchProcessID=2736 (True);Config=;Arguments=--scrypt -o stratum+tcp://doge.netcodepool.org:4093 -u geokilla.1 -p 1234 -I 15 --thread-concurrency 24000 --lookup-gap 2 -g 1 -w 256;HasFullAPIAccess=True;KillOnReadOnlyAccess=True;IsBatCmdFile=True;ProcessID=4928;bat ProcessID=2736.
[16/12/2013 2:01:42 AM] [d] Miner.StopMining - command window killed to ensure successful restart.
[16/12/2013 2:01:42 AM] CGMiner process closed outside of CGWatcher! Use the 'Ensure miner stays running' monitor option to have CGWatcher restart the miner when this happens.
[16/12/2013 2:01:45 AM] [d] Miner.IsProcessAlive(4928) returns False. [First try, test process is nothing. ex: Process with an Id of 4928 is not running.] (CPID0/CMPID=0/CBPID=2736)
[16/12/2013 2:01:45 AM] [d] Miner.StartMining (for restart) called. [Profile=NetcodeDogePool;MinerFile=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\NetcodeDodgePool.bat;MinerFileUsed=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\temp_NetcodeDodgePool.bat;MinerExecutable=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\cgminer.exe;Config=G:\Downloads\Litecoin\CGWatcher-1.3.3\temp.conf ();Arguments=/c;Anticipated Port=4028;Used Port=4028;HasFullAPIAccess=False;IsBatCmd=True;BatCmdPath=G:\Downloads\Dogecoin\cgminer-3.7.2-windows\temp_NetcodeDodgePool.bat (G:\Downloads\Dogecoin\cgminer-3.7.2-windows\NetcodeDodgePool.bat);LastKnownInstanceCount=0/0]
[16/12/2013 2:01:46 AM] [d] BAT successfully launched CGMiner executable process using ProcessID 5584.
[16/12/2013 2:01:46 AM] [d] Miner.IsProcessAlive(5584) returns True. [First try, process is alive.] (CPID5584/CMPID=5584/CBPID=6084)
[16/12/2013 2:01:46 AM] [d] Waiting for CGMiner to initialize API. Process 5584 alive=True, minerid=5584, bat id=6084.
[16/12/2013 2:01:47 AM] No pools set in config file or arguments! If I need to restart the miner it will be stuck at prompt until you manually enter this information. Putting this into the config file or arguments is highly recommended to ensure continuous mining.
[16/12/2013 2:01:47 AM] [d] Watch for miner, expected process is 5584 (alive).
[16/12/2013 2:01:47 AM] [d] CGMiner process is running using ProcessID 5584, expecting port 4028.
[16/12/2013 2:01:48 AM] [d] CGMiner running but without API access... waiting to check again.
[16/12/2013 2:01:50 AM] [d] CGMiner running but without API access... waiting to check again.
[16/12/2013 2:01:52 AM] [d] CGMiner running but without API access... waiting to check again.
[16/12/2013 2:01:54 AM] [d] CGMiner running but without API access... waiting to check again.
