Cryptocoin Mining?
Page 165 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
thilanliyan
12,085
2,281
Yeah I was experimenting. Some how I got the second card to be noticed by the miner and can get the clocks up, but now they are both boosting their Mem clocks as if I were gaming.
I used AB to for all my clocks, but 900mhz is the lowest I can get the mems with it so I left it there.
What you may have to do for the memory is lower the memory clock all the way, switch the "active" card in AB then switch back and you should be able to go lower on the memory. That's odd that you can only go to 900MHz though. Even without doing the above procedure, I can go down to 600MHz on the memory.
There must be some settings in AB that is causing that. Extended clock limits or something like that? Are you using the newest version of AB?
railven
6,604
561
Okay...so I'm not even sure if I set my account up right. So, here are the steps I took if someone wants to let me know if I did something wrong BEFORE I realize I'm not minting.
I downloaded Bitcoin Wallet (bitcoin-qt), I used the address under the Address Book to register an account over at Mt. Red.
I used that account to log into GUIMiner and clicked start.
Is it really that easy? How can I verify if I'm actually mining and the data is being sent to my wallet?
railven
6,604
561
I'm using: AB 2.3.1
The lowest the slider goes is 701mhz, but when I go below 900mhz the clocks just revert to factory stock (1325/1425). So just left it at 900.
Before when I couldn't get the second miner to go, I had one card doing 1150/150 with the other doing 500/350.
But at least now both are mining at full clocks :D
chimaxi83
5,457
63
101
1100 core gets me just under 650 mhash. Are you setting flags in the guiminer window? Here is my setup for flags: -v -w 256 -f1
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
Yeah, all of that sounds about right - although usually I have to put in a few flags (-w 256 -v 1) to get throughput up.
To make sure something is happening, on MtRed's website, click "Mining" and then "miners" and you should see numbers next to your worker indicating that it's doing something. Money doesn't directly go to your wallet. You need to set up autopayment and then have enough bitcoins to exceed the threshold required for autopayment.. and then after it pays automatically - or you initiate it - you should see it show up in your wallet... after a while has passed.
thilanliyan
12,085
2,281
Your stats page at MtRed should show how much you have minted, your hashrate, etc. As for the address, make sure that is the address you are asking MtRed to send coins to. Make absolutely sure you copy and pasted it correctly. Did you set an auto payout threshold? Set it really low for now (ie. <1.0BTC) to see if you are actually mining and getting it sent to your wallet properly.
I'm using: AB 2.3.1
Try Sapphire Trixx since both of your cards are Sapphire cards.
railven
6,604
561
I just entered those flags and shot up to ~630Mhash each card :awe: So thank you for that tip!
I logged on to Mt. Red and it doesn't show me anything in my miner's tab. Why I decided to ask if I set it up right.
thilanliyan
12,085
2,281
Username and password correct in Guiminer? The user/pass would be different to what you use to log into the MtRed site. Each mine worker would have a different username to your site username (usually). Sorry I can't give specific info...I haven't used MtRed in a while...I was using BTCGuild for the longest time.
railven
6,604
561
I'm looking at the miner page, and I realized I have to create miners? I assume that is what you mean? I'm gonna test that right now.
Thanks again.
li888
9
http://www.newegg.com/Product/Produc...82E16814202006
This one is $269 after rebate and the games will get you at least $50 so $220
Oh sweet! btw can I use the 7750 as the display output/gaming card and the 7950 as the miner card? BTW this is for LTC. And use them both at the same time for mining? I currently use guiminer scrypt alpha. Thanks guys!
Also, a 6950 is 170 right now. Is the cheaper price worth the extra energy usage?
railven
6,604
561
Thanks for the Help. I went and signed up with BTCGuild, used their directions and it is actually showing my miners working so I'll stick with them.
Mining related questions would get answered more completely and faster over at bitcointalk's subforum for mining: https://bitcointalk.org/index.php?board=14.0
Sorry, I didn't have an account there and figured this was a good place to ask a few questions.
24601
1,683
40
86
Massive DDoS of notroll.in, litecoinpool.org, burnside's pool (ltc.kattare.com), coinotron.com, ltcmine.ru
<span style="text-decoration:line-through;">eu.notroll.in still up.</span> down
Someone is trying to tank litecoin's exchange rate to get some good old pump and dump in and is switching to the pools full throttle after failing to take BTC-e down.
ultimatebob
25,134
2,450
Yeah... Burnside is completely down right now, but Coinotron is up. Getting into BTC-e was pretty tough there for awhile.
Ah, the joys of an unregulated electronic banking system...
Binky
4
I currently run a 6950, 7950, and 7770, and the 6950 is the worst of the bunch. It's hot, noisy, doesn't overclock well, and it's just plain finicky. The 7950 is worth the extra cost, both for gaming and for mining. The 7770 is also surprisingly good, as long as you're ok with ~200mhash max.
chimaxi83
5,457
63
101
I just went online to check my miner's and saw them sitting at 0.0 for the last 1hr and a half.
Now I'm worried something happened to my rig :(
That used to happen for me when I was still fine tuning my clock/voltage combinations. If your display driver crashes and resets, it will stop mining. Just have to caress it a little :wub:
Binky
4
It may be time for a dedicated LTC thread. It's very confusing trying to figure out what each post is talking about...!
railven
6,604
561
Haha, thanks for the reassuring thoughts. My first reaction is always the worst case scenario.
Perhaps I shouldn't be price checking a new Radeon yet, huh? :awe:
Elfear
7,169
829
Depending on what your workplace will allow in terms of software on your computer (mine won't allow most 3rd party stuff), there is a cool app you can get for your phone that allows you to remote into your home computer. I think it's called Teamviewer IIRC.
I used that for a while when I was just getting my mining rig going. Helped to reset AB or the mining client rather than wait all day until I could get home.
chimaxi83
5,457
63
101
Oh yeah, good idea. If you can't install something at work, use your phone :thumbsup: TeamViewer for Remote Control. Not sure how well it works, but now I'm going to try it :D
