HAL9000
How do you figure no brakes is better than the hand brake???
How did you get that from what I said????
I imagine the first thing I would do (and have done) Is drop it into neutral then drive into a bush or something to slow me down (they do the same thing on Top Gear) I definitely definitely definitely wouldn't pull the hand break going anything over 20mph.
I'm guessing the CC did actually stick (or his throttle or whatever), and he panicked. Once the officer slowed him down a bit, the drivers wits took over and he shut off the ignition.I was wondering that, too. seemed odd that the cop could somehow stop his cruise.
though, if tapping the break truly didn't work, then something had to up with his CC, no? or maybe it wasn't actually on?
I'd rather things weren't described as "emergency" when they shouldn't be used in an emergency... But what are you going to do when American decides something stupid like this?
Backup break would make more sense for the use you are describing.
There's something to this story we're missing... His cruise control wouldn't allow the car to slow down, but when the cop pulled in front of him and impeded his path... What made the cruise control stop trying to go 60mph?
If it were truly stuck, and the driver didn't turn of the ignition, it would continue to try and accelerate.
And when would you use a back up brake? In an emergency.
And when would you use a back up brake? When your primary brakes fail...which is an emergency.
Let's say that your emergency is that your hydraulic brakes go out... Why would you NOT use the hand brake???I'd rather things weren't described as "emergency" when they shouldn't be used in an emergency... But what are you going to do when American decides something stupid like this?
you said you absolutely will not use it if you can't stop your car. you'd rather drive into a tree or bush or something.
in several posts, you vehemently demanded that no one use this break in an emergency situation--which very much implies that you prefer to use no break at all if your hydraulics fail.
Yeah that's not what I was getting at, I'd rather have a hand brake than no brakes.
In a very specific emergency, I.e. when the breaks are out, you are doing under 20mph.
When you want to do what is technically (in the UK) called an "Emergency Stop" You do not use a hand brake! D:
He would... But I'd take that over a stuck throttle any day!Couldn't he just turn the engine off, or would he lose braking and steering power?
Why not over 20mph... What exactly do you think will happen, other than the hand brake would slow you down.In a very specific emergency, I.e. when the breaks are out, you are doing under 20mph.
...then why are you saying that it should never be used in an emergency situation, when you have no braeks?
Like I said, I'm guessing he panicked and didn't consider that option. I also don't buy the fact that he couldn't shift into neutral.
Perhaps you play too much Need For Speed? 😉
1) It wouldn't work at any speed
2) It would lock up the wheels and you'd just skid
3) If you were turning the wheel you'd spin
4) You'd probably snap the cable
5) You wouldn't gradually come to a halt.
6) You could slow down more effectively by changing into neutral and letting the car slow down naturally.
I think I'm gonna call bullshit on this one...
There are so many fail-safes on cruise control it's not funny.
Cruise control is supposed to release if:
You touch your brakes
You touch the gas
The speed varies by more than 5mph
I've never been in a car that couldn't be dropped into N while driving... or at the very least shift down into 3-2-1 gears which would slow the vehicle by more than 5mph
And why is it that his brakes couldn't stop his car but the cop's SUV could stop both?
And what happened at the end? Was his engine still grinding away trying to go 60?
None of this makes any sense.
1) Of course it will help.1) It wouldn't work at any speed
2) Only if you jam on on with full force. You can certainly mitigate the pressure.
3) Umm... Don't turn?
4) LOL, not hardly.
5) Of course you could.
6) Slowing down without brakes is more effective than with brakes???
Have you ever actually USED a hand brake while driving a real car? I'm guessing not.
Uh, you don't rip on the brake. You gradually apply it.
Please go and learn how to drive.
