OK, I'll just pop out, back in a few months.![]()
Thanks. Please make constructive use of the free time.
In the UK it's a hand brake...
Umm... wrong but for the sake of argument, ok.1) It wouldn't work at any speed
Thought you said it wouldn't work at any speed... :hmm:2) It would lock up the wheels and you'd just skid
Thought you said it wouldn't work at any speed... :hmm:3) If you were turning the wheel you'd spin
Umm... no.4) You'd probably snap the cable
When you're rolling out of control who cares if you stop gradually?5) You wouldn't gradually come to a halt.
On an incline sure... maybe. On flat land... meh. Both assuming you're not in any traffic..6) You could slow down more effectively by changing into neutral and letting the car slow down naturally.
How much sense does it make when "hand brakes" are used by your foot in most automatic cars?
I either call it an e-brake or a parking brake.
OMG NO!!! DON'T DO IT, YOU WILL DIIIIEEEEEE!!!Pull the e-brake!
Oh wait, you're not in England. Nevermind.
I think I'm gonna call bullshit on this one...
There are so many fail-safes on cruise control it's not funny.
Cruise control is supposed to release if:
You touch your brakes
You touch the gas
The speed varies by more than 5mph
Here's a picture of one on the floor:
http://www.ford-taurus.org/taurusinfo/Features/P-brake.jpg
My car's cruise only disengages if I turn it off, cancel it or hit the brakes. I manually accelerate and set the cruise to the new speed all the time. My car still says "SET", but it won't do anything unless my speed drops below that point again.
Every cruise control I've ever had would disengage if you stepped on the gas.
My G does not disengage when I hit on the gas.
Set at 75, get on the gas to pass up to lets say 85 now, take my foot off the gas and it will coast back to 75
neckbeard, every car has an emergency break. you spend all your time blasting automatic transmissions, yet you would not be able to function in a manual without the fucking emergency break.
also called a "hand break."
in some models, it is a button on the floorboard, activated by the driver's left foot.
or a lever to the left and under the steering column.
not really. I have no idea why it is called an emergency break, other than it isn't always a hand break.
I suppose it may be because people would use it to stop their cars from rolling away or most commonly (since the majority of cars are automatic), as backup when parking on steep inclines.
It's actually illegal in SF to leave your car parked without the emergency break applied.
so I guess, in a sense, it is to prevent accidents....
It was formerly known as an emergency brake in older cars where it would be the only braking option in case of primary brake failure. If slowly applied it could sufficiently stop a vehicle (well, better than no brake at all).
Modern cars retain the lever more for the purpose of parking assistance.
Hmm Interesting, I still can't imagine it would work well even when "slowly applied" I think it would be very dangerous when going at any kind of speed.
That's my point, it won't work in an emergency...
My point is that calling it an "e-brake" is retarded.
Alright, let's me and you take two identical cars out. Mine will have an e-brake, yours won't. The brakes in both cars will fail.
Let's see who's able to stop his car.
It's like saying that have two windscreen wipers is better than one, so call the passenger side on an emergency wiper...
Yeah it's better than one, but DO NOT use it in an emergency! You will cause emergencies for others. It's used pretty much exclusively in parking.
oh yeah, it's called a parking break too. Actually, that's what I called it first. makes more sense. Where I grew up, it was always either parking/emergency.
Now I mostly call it hand break, but also emergency break due to force of habit.
Are you making fun of Zin's spelling or sticking to your guns in your trademark fashion?Yeah that does make a lot more sense... Emergency break is a very confusing name for it...
I imagine the first thing I would do (and have done) Is drop it into neutral then drive into a bush or something to slow me down (they do the same thing on Top Gear) I definitely definitely definitely wouldn't pull the hand break going anything over 20mph.
I'd rather things weren't described as "emergency" when they shouldn't be used in an emergency... But what are you going to do when American decides something stupid like this?
Backup break would make more sense for the use you are describing.
you said you absolutely will not use it if you can't stop your car. you'd rather drive into a tree or bush or something.
in several posts, you vehemently demanded that no one use this braek in an emergency situation--which very much implies that you prefer to use no brake at all if your hydraulics fail.
...then why are you saying that it should never be used in an emergency situation, when you have no braeks?
...Cruise control is supposed to release if:
You touch the gas
I've never been in a car that couldn't be dropped into N while driving... or at the very least shift down into 3-2-1 gears which would slow the vehicle by more than 5mph.
Yeah, because the driver obviously couldn't grasp the concept of turning off the ignition and robbing the engine of electricity that sparks the combution process in the first place. Oh, and I am sure the driver never thought about simply slapping the transmission lever out of Drive and into Neitral.http://www.click2houston.com/news/28747312/detail.html
I think that's pretty incredible, I'd have been shitting myself.
One question though, the guy says he "tried the emergency brake" WTF?! What cars have an "emergency brake" and the cars that do, how can it not work?! This is exactly what that is designed for... surely?!
Dumb is as dumb exists ... in Huntsville, TX.![]()
Why are people so concerned about the e-brake (hand brake), there is no mention of the hydraulic brakes failing (breaking) in the article - so all the driver would have had to do is stand on them and keep them pressed into the floor.
Several people have tried wide open throttle (WOT) and mashing the brakes at the same time (after the Toyota incidents (WOT + braking not recommended BTW))- guess what? The brakes win and you will stop. Granted if you let off the brakes you will accelerate (as per the Toyota case, where the guy had several "goes" at braking and overheated them...). So the PSA on this is if your car gets in a situation where the throttle is stuck (for whatever reason), stand on the brakes and keep the pedal nailed to the firewall... (also try neutral/engine off after pedal fully mashed into the floor).
The second point is that the emergency/parking/hand brake may not bring you to a stop when the throttle/CC is jammed open, as the engine will provide more power as the load (E-brake) is applied.
