Originally posted by: BFG10K
I would agree with that, but why is the fps for the single card 29fps and the fps for the dual card setup 24 when their own benchmarks don't mirror this? They are either not comparing the same card in the single and multi-card setup, or they are using a specific snippet of the frame log to illustrate their point.
Like I said I only have a theory that it?s somehow related to AFR simply because the first frame takes longer to arrive and then offsets the rest.
I can almost certainly say they
didn?t do something stupid like compare 9600 GT SLI to a single 8800 Ultra because that wouldn?t prove anything.
I'm saying that if the duration for AFR never exceeds that if a single card, the AFR system is no worse off than the single card. They may both in fact stutter depending on the length of a given duration.
If the duration is shorter for the AFR system than the single card, you will NEVER experience a drop in frames or micro stutter with the AFR system that you would not also experience with the single card system.
Okay, but my example shows a scenario where AFR could be worse despite the durations never exceeding the single card. What is your response to this?
It depends on the duration... If the total duration between frames for the 2ms swing was 30ms and 32ms, and the total duration between frames for the 9ms swing was 20ms and 29ms, the one with the lower duration is still providing you with the better experience.
Huh? Where did you get those figures from?
I already explained that the single card alternates between 45 FPS and 50 FPS while the AFR card alternates between 55 to 110 FPS.
So the single card would look something like this:
1 22 ms
2 20 ms
3 22 ms
4 20 ms
While the AFR card looks like something like this:
1 18 ms
2 9 ms
3 18 ms
4 9 ms
So according to you the AFR system is better off than the single card system because at no time do its frame durations exceed that of the single card? Again I wouldn?t necessarily agree with this, not when AFR is constantly cutting your framerate in half and then rocketing back up again.
With those kinds of constant swings it?s quite possible someone may notice them more than the framerate jumping between 45 FPS to 50 FPS on the single card.
What do you think causes these irregularities? Hint: a longer than normal duration between frames.
What causes the irregularities is fluctuating framerate that isn?t necessarily picked up by framerate counters given they typically poll only once per second.
If you were experiencing micro stutter with a multi gpu setup and the durations were consistently lower then a single gpu setup, the single gpu setup would be stuttering continuously.
No, like I explained above that isn?t necessarily true at all.
