Originally posted by: Tainer
they only cover the front 5 or 6 teeth.
so they give you 28 strips for the upper and 28 for the lower.
but each strip only covers about 5-6 teeth?
what about the back teeth and the big molars and such?
do we have to buy more to whiten those?
Originally posted by: ActiveX
do you wear this thing overnight? one person said it didnt work, another said it did, so does this thing work or is the dentist the only way to get those stained teeth clean?
Originally posted by: AntMan530
MUY HOT!!!
I bought some last week because I couldn't afford the $200 bleach service from my doctor. One week has gone by and my teeth are noticeably one to three shade whiter. It's possible that the my new tooth paste might be the culprit in stimulating this intense whitening process. The only problem I have is that,it doesnt get in between your teeth very well. The trick, (advise from my dentist) is to use a tooth pick and smear in down. Can you picture it? hehehe... Of course gently so you won't tear the strip.
Anyhow...HOTS..
Originally posted by: dakata24
which is better, the colgate simply white or the crest whitestrips?
Anyways, the other hand. Colgate simply white, is also a whitening gel and it also has a guarantee (not limited to time) and it only takes about a week to notice the difference. It requires you to apply the gel to your teeth and not eat for 30 mins after that, but its worth it. The effects are great.
Originally posted by: Yzzim
My girlfriend loves these strips. I originally bought them for myself but she got ahold of them and I haven't seen them since. She said my teeth were too white already and somehow that means she's justified to them![]()
Anyway, her teeth do look much whiter. She's used about half the package, once/day and I can already tell a difference.
You do not keep these on overnight. Put them on for about a half hour and then brush your teeth when you're done.
I heard that there's like 4% bleach in the gel on the strips, while the Professional strips you get at the dentist have 8% (or so) and the platters that the dentist use to whiten your teeth have 12-14%. Can't remember the exact numbers, but it's something like that.
Originally posted by: bigtee
The price of Whitestrips has been decreased by 30%. Target, Walmart, etc should all be selling CWS for about $25.
Link
