Question CPU Upgrade Issues
pal007
Hi All
I upgraded my laptop HP CPU from Intel Pentium P6100 to Intel Core i5 460M.
Laptop model - HP G62
Though I was able to boot the Laptop without any issues, the clock is showing incorrect time. I manually reset / sync ed with internet time server, which fixed the issue for the moment.
Exactly after 1 hour the clock resets to the time before the manual reset. This keeps happening every 1 hour. Any thoughts ?
Other important thing is the wi-fi does not work after an hour also. I need to restart. When I restart , the internet works.Is this some hardware fault (wifi cable fitment issue) when I repacked the laptop ?
Note - The BIOS is latest. Though I did not update the BIOS before the CPU upgrade.
Refer the attached spec
Please let me know your thoughts.
pal007
By battery do you mean the CMOS Real Time Clock battery ? But then how does it work for an hour & then reset to the time (exactly an hour back) ?
Is it because wifi is lost, time resets to old time recorded somewhere ?
VirtualLarry
56,572
10,208
The laptop reboots itself, or shuts down, or resets, or whatever, every hour, right? That's the Intel chipset lockout. You CANNOT upgrade a laptop that came with a Pentium, to a higher Core CPU. THEY WON'T LET YOU. (*) Unless your laptop mfg used the higher end chipset that's supposed to be used with Core CPUs, with a Pentium. In which case, you lucked out.
Edit: If it's just the time, are you certain that your timezone is set correctly, including the switch for DST? It probably goes out and syncs the time with internet time protocol servers every hour.
Reactions: damian101
pal007
Thanks for the response. Yes the timezone is set correctly. It syncs with the 'internet time server'.
When I try to manually sync, it throws the error. refer attached image.
Shmee
8,145
3,081
What OS and is it a clean install?
Shmee
8,145
3,081
Hmm, I wonder if win 7 is having some issue now communicating with internet time servers due to EOL. can you try a Linux environment, something light like Lubuntu?
