Hi, in the BIOS there is a setting when calculating the CPU speed, one reads 100 mhz, the other 133mhz. Is this the memory speed? Mine is PC133 ram but when I run my computer at that speed it runs fine for a while then crashes shortly after. 100mhz it runs flawlessly. If someone can enlighten me as to what the problem could be I'd greatly appreciate it. 3dmark gives me ~80fps top in the first car chase demo at 100mhz speed but when I run it at 133mhz it goes up to ~105fps but then freezes shortly through the demo.
