- Sep 18, 2002
- 13,990
- 1
- 0
Originally posted by: Skoorb
I don't take no cap off my master cylinderOriginally posted by: AMCRambler
Yes, and actually you don't need to take the discs off, just the calipers. If it is disc brakes that is. It's really not hard, on my car all you do is take the wheel off take two bolts off the caliper and pull the caliper off. The pads sit in a mounting bracket right against the disc you just pry them out with a screw driver since they fit in pretty snug. The hardest part will be compressing the pistion on the caliper since the new pads will be much thicker. On mine you take the cap off the master cylinder and compress the piston with a c-clamp. Once the caliper is back on put the bolts back in and wheels back on. Don't forget to put the cap back on the master cylinder either. Not sure how different Nissan's are but they can't be that different. I'd recommend getting a Hayne's service manual for the car. They'll tell you exactly how to do it.Maybe I should though I dunno! Also get a LARGE c clamp. I bought a set and they were too small. Go to home depot and get a bit mother. I also advise getting a haynes for the pictures, but it's a job you can do.
Does it sound like metal grinding on metal? My brakes did that when one of the bolts came out, but only in reverse.
