- Jun 28, 2012
- 537
- 0
- 0
I agree with you, Throw it in the rear fan location and leave the 200mm up top.
price difference between H100 and H80 is small ... but performance is same and H80 is less loud yes ?
price difference between H100 and H80 is small ... but performance is same and H80 is less loud yes ?![]()
I think noise would be about the same, if you are going the dual radiator length route consider the swiftech, but if you go with the 120 radiator product lineup make sure you get the h80i and not the older style h80. Its has a better pump and software controlled fans.
I really dont know how the h100/h100i performs with a 200mm fan but I will see if I can find a review after work.
The Noctua D14 is cheaper than the H80i and cools better according to multiple reviews. The Noctua also doesn't require space for a radiator--just room around the CPU socket.
