Virgorising
Wow! This one looks even better! THANK YOU!!!!
you referring to Burpo's post? if so then even at 100% minimum the cpu still clocks down at idle.Well, it would be nice to at least have the CPU's clock down when idle. Kinda overkill to turn that off entirely.
why? dropping to idle speeds and core parking are 2 different things.K....NOW, I am confused again.😳
I have mine at 100% minimum and I am sitting at my Sandy's idle speed of 1.6. same thing on my E8500 as it was always set to 100% but idles at 2.0 just like it should.It might go into a lower C-state maybe (I haven't bother to confirm that), but it 100% will not throttle down clock speeds if you set the minimum state to 100%.
That's the entire purpose of that setting.
For example, I just tested this right now on my i7-4770k running on stock clocks. With minimum set to 5%, the clock will drop to 800MHz on idle. With it set to 100%, it actually stays at max frequency the whole time.
Just walked in and saw this.....well, that makes me feel better, but I am still afraid to turn it off, cause I remain unclear re the downside.
i.e., if I turn it off and no cores get parked ever, will the cores have higher temps than now? Cause now, they are mostly around 28C
Right now, apart from cores getting stuck in park in W7 (OMG!!!!!😱), my feeling is this thing is in place for maybe good reasons?
When I can, what I think I should do, is do some video converting.....the only thing I do(and not often) that is CPU intensive. During that, I would look again and see if the same 4 cores are parked. If they are, that would be messed us, and maybe sign the parked ones are stuck, yes? I will use that app to turn the whole parking thing off.
But it will still creep me out a little.
Pls comment! I just do not wanna do anything to mess anything up.
Remember, late last nite was the first time I ever even heard of this thing!!!
Thanks as always for any feedback.
Virgorising, some of my prior posts on the topic of (and issues therein) "core parking" might help put you at ease. I will link them here for you perchance you have the time and desire to peruse them 😉
The issue of "core parking" when using "processor affinity" in Task Manager
http://forums.anandtech.com/showthread.php?p=35408462&post35408462
http://forums.anandtech.com/showthread.php?p=34813419&post34813419
http://forums.anandtech.com/showthread.php?p=34404101&post34404101
http://forums.anandtech.com/showthread.php?p=34117056&post34117056
http://forums.anandtech.com/showpost.php?p=34077467&postcount=618
http://forums.anandtech.com/showthread.php?p=33897568&post33897568
:hmm: Now that I've assembled my list...me thinks perhaps I have been a bit too active in campaigning against core parking!? 😛
I'm really not that much against it, I just see it as a good idea that has yet to be properly and robustly implemented.
Don't worry about disabling core parking. Your CPU will still power-gate the core and drop the power consumption to near zero when the core is idle.
Disabling core parking simply prevents windows from getting in the middle of it all and screwing it up.
Consider the point that if Microsoft really knew what it was doing when it comes to managing the power-savings features of your CPU then the CPU manufacturers would not need to ingrain these features at the hardware level from the outset.
Entrust your power saving features to the skilled hands of the CPU designers at AMD and Intel, not to the questionably bureaucratic programming hierarchy that prevails at Microsoft (yielding such gems as Win98, WinME, Vista, and Win8 🙄).
It is easy to test, simply run the program that disables core parking and then re-run your tests.
If the results show improvement, then leave core parking disabled.
If the results show no tangible improvement (or, possibly, a lowering in performance) then simply reuse the same program to re-enable core parking.
Either way you will have your answer in a matter of minutes.
you have to restart your computer.
