jlee
Yep. I use impact drivers for nearly everything. They're amazing.Is... is he using an impact driver to drill that hole?
https://www.thesprucecrafts.com/compact-power-for-drilling-and-driving-3536597
Drilling with an Impact Driver:
Can you use an impact driver as a drill? Absolutely. Matter of fact, drilling clean holes with a spade bit is actually much easier with an impact driver. One of the problems with drilling large diameter holes (1/2-inch and wider, up to about 1-3/8 inches in diameter) with a spade bit is that the bit can pinch and get hung up in the hole. When the bit gets stuck in the hole with a cordless drill (or worse, a heavy-duty high-torque power drill), a rotation that the motor was applying to the drill bitand chuck is then transferred to the body of the drill, twisting the drill in the user's hands. In the best of cases, the drill will slip out of the operator's hands, or worse, the twisting drill's torque can be transferred to the operator. I can't tell you the number of times I've hurt my wrist from having a spade bit stick in the hole.
