Cooling down my Room
RossMAN
Grand Nagus
Feb 24, 2000
79,057
446
Originally posted by: elwood
Originally posted by: bobert
thermostat regularly set at 80, and is about 83-85 in my room in the middle of the day
just checked right now, 79.9 in my room
Damn, thats hot. I like sleeping in a "refrigerated" room. We usually set the Thermostat to 72F when we're not sleeping and 69 when we are. 69F is where it's at!!
It would be so perfect to sleep in a 65 degree room. Unfortunately my wife probably wouldn't go for that.
Your not very lucky. Coldness is better.
WTF goes on in that empty head of yours?
We must save the world before Peter destroys it.
Peter Pan
Peter Parker
Peter Petrelli
Savarak
2,718
after living in chicago for so many many years of my life and now moving to tucson(its been almost exactly 1 year now!!) and buying a house... I'm actually freezing at night with my AC set at 76/77 degrees... :( its so cold...
btw electricity bills suck
pcslookout
11,959
157
Peter Pan
Peter Parker
Peter Petrelli
Heroes
AlienCraft
10,539
Run a duct from the exhaust of your computer to the window.
You could also exhaust it to the attic.
That too.
this would require cutting a hole, that would need to be sealed to properly work , and would add additional heat load at the ceiling and would need to be fixed upon departure.
Better to run it to the hot air return of the A/C unit to provide a higher deltaT at the heat exchanger coils.
It is, after all, where the hot air is designed to go to be cooled.
fustercluck
7,402
*bump*
Any other other votes for a humidifier? I could actually afford one of those, as opposed to some other methods of cooling. I wonder how much a humidifier would actually help though.
Squisher
21,204
66
Originally posted by: Adaman
Another other votes for a humidifier? I could actually afford one of those, as opposed to some other methods of cooling. I wonder how much a humidifier would actually help though.
To make a room seem cooler you would need to de-humidify it. The problem with most dehumidifiers is that they add a certain amount of heat to the surrounding area. Most times this is negligible, but in the small confines of a single room it could cancel out any dehumidification.
