Cooling down my Room
fustercluck
7,402
Originally posted by: Phoenix15
Originally posted by: Adaman
My computer isn't on 24/7. Just whenever I'm awake, which is still kinda close to 24/7.
Close all the registers? I assume those are the vents? Never heard them called registers before. It'd be nice if there was a system that could automatically close 'registers' to rooms that are empty and open them up to room with people in them.
I don't think a window unit (AC?) would fit in my window. My window is about 5 nches, depth wise.
Opening the Window at night isn't much of an option anymore, it's hot at night now also...which means almost pool time, yippie!
Get a humidifier. I paid around $40 at Wal Mart for one and it makes a BIG difference. My living room has floor to ceiling windows on one side, so all that sunlight would heat it up quick. With the humidifier stuck in a corner turned on low, there is about a 10 degree difference in the room now.
What are the downsides to a humidifier? Are they loud? Do they get...moisture everywhere? I dunno :p
pradeep1
1,099
I have the same problem in my office at home. It is west facing, so during Summer, when the sun is setting it cooks that room. On top of that, the room has three beefy computers running 24X7. In winter it is nice, but in summer it sucks. It is easily 5-8 degrees hotter in this room than in the rest of the house. One way to keep myself cool is with a small fan on the floor aimed up towards me. That works pretty well. Forced air, just like on heatsinks, works well in cooling you down.
A window unit AC is nice, but they eat up a lot of power, and with the price of power going up, they may get expensive to run all day. One other idea to consider is that your AC unit's flexible pipe ventilation into that room may be crimped or partially blocked. Climb up in the attic or go in your basement and check to make sure the cool AC air is getting in there.
Good luck.
sierrita
929
Huh? Most windows are about 5-7 inches, depth wise. That's not likely to be a problem.
More likely, being in Tucson, you may have sliding windows, which are somewhat problematic for installing a window unit, although it certainly can be done.
I'd play with the registers first, however. It should solve the problem and the cost is $0.00.
RossMAN
Grand Nagus
Feb 24, 2000
79,006
430
Are your windows vertical (up and down) or horizontal (sliding left to right)?
Phoenix15
1,587
Mine is not loud at all. If you crank it all the way up it makes about as much noise as a regular fan, but down low it is not noticable. It doesn't get things sticky or anything. :D
f4phantom2500
2,284
My room is the hottest room in the house, I guess because of my computer. Thermostat is down to 75 but it's like 78 in here (it's a big difference, trust me). The rest of the house is 75. I'm in Tucson so that doesn't help, already over 100 degrees outside. Looking for a cheap way to cool down my room a few degrees. I don't have much room in here so hopefully the cooling answer i'm looking for comes in a small package. This is the kind of thing I'd normally ask on Yahoo answers, but, has anyone actually used that? It's horrible. ATOT to the rescue...again!
Same thing happens to my room. The house is at a cool 73 degrees, but my room gets up to 91 degrees sometimes. I have a ceiling fan, an open window, and another fan in my room. Im not sure if it's my computer or not.
don't have the window open when it's hotter outside than it is in the room, it'll just make it even hotter. i used to do the same thing but found that i could only do that at nights during the summer because if i did it during the day it made the room too hot; believe me, keeping the window closed makes a difference if it's that hot outside (Texas, usually gets up to ~115 or hotter during the summer). basically keep a bunch of fans on, keep the door open to the rest of the house if you can, preferrably keep a fan at the door so you can blow cold air into the room. the window thing is fine during the winter though lol.
Originally posted by: PingSpike
Here's some cheap/free tactics that I use:
1) Good sized fan angled up the stairs in my basement...pushes cool basement air into the rest of the house.
2) Close windows and blinds during the day, open them at night. Its crazy stupid how well this works...and I can't believe we never did this when I was a kid. We always opened the windows when it got hot...that just lets hot air and sun into the house.
3) Compact fluorescent bulbs...they use less energy because they don't emit as much wasted heat.
My computer room is still hot during the summer though. But I don't use an air conditioner. I live in Vermont though, I doubt these tactics would work in arizona!
Actually, they work pretty well here in Texas (except we don't have a basement and we keep the AC on anyway lol). Same rules of thermodynamics, just set the AC up to balance out the fact that it's hotter outside lol. Your tips probably work better down here actually since there's a larger delta between the inside and outside temperature here.
Gunslinger08
13,234
I have the same issue. My bedroom is in the basement with no windows, and I have a computer always on and a plasma that pumps out heat. There's usually a 5-10 degree difference between the bedroom and the rest of the basement. No central air + no windows = no cooling.
fustercluck
7,402
The window opens horizontally, the blinds close vertically.
AlienCraft
10,539
Originally posted by: ggnl
You can put a fan either blowing into or blowing out of the room to try to circulate the air with the rest of the house.
QFT
circulate the hot air off the ceiling with an oscillating fan.
SZLiao214
3,270
Originally posted by: Anubis
what kind of monitor do you have?
Ah the good old days playing computer games during the summer with a 17 inch crt and a crappy ac. Good changes :)
AlienCraft
10,539
DO NOT Close the registers. Doing this will not force more cool air into a particular room as residential systems are usually not sized with any "headroom" in them. The ducts can only move a certain amount of CFM and adding additional load only puts pressure on the system where it is not designed to.
Increased airflow resistance slows the air flow, increase head pressure and may cause premature compressor failure or icing up.
Check the filter in the hot air return. 99% of all A/C service calls are the result of a dirty filter restricting airflow.
You need to maximize the efficiency of the system and this is the easiest way to do it.
Reduce or remove any heat producing devices.
Coquito
8,559
Consolidate your crap & make room for air to circulate.
imported_elwood
828
A small 5000BTU window AC is all you need. Put dark tint on all your windows. Or, if you're like me and work nights (sleep during the day) put aluminum foil on the windows! Cutting out all that sun from coming in will keep the room A LOT cooler. You won't be able to see outside but who cares..the outside is for loosers! (j/k)
EDIT: I guess i should learn to read the entire thread before posting. (horizontal windows). Hang on...i seen something on TV that might be able to help you.
EDIT # deuce: This is what i was talking about. $2500 installed for their cheapest unit, 9000BTU, is expensive. You can get a 13k BTU window unit for $200.
It would be cheaper to hire a carpenter to come and cut a hole in your wall for a damn window unit.
Good luck...there wont be much you can do without spending a few hundred.
I think the simplest thing would be to put a fan in your doorway sucking the colder air from the other rooms/hallway into yours and drop the thermostat a few degrees to compensate.
RallyMaster
5,581
78F is hot? That's the temperature I go running at..... learn to tolerate the heat....or move out of AZ.
bobert
505
thermostat regularly set at 80, and is about 83-85 in my room in the middle of the day
just checked right now, 79.9 in my room
imported_elwood
828
Damn, thats hot. I like sleeping in a "refrigerated" room. We usually set the Thermostat to 72F when we're not sleeping and 69 when we are. 69F is where it's at!!
RossMAN
Grand Nagus
Feb 24, 2000
79,006
430
It would be so perfect to sleep in a 65 degree room. Unfortunately my wife probably wouldn't go for that.
pcslookout
11,959
157
Your not very lucky. Coldness is better.
RossMAN
Grand Nagus
Feb 24, 2000
79,006
430
WTF goes on in that empty head of yours?
pcslookout
11,959
157
We must save the world before Peter destroys it.
