Ok guys, I know when I am beaten. Even though the Antec compound looks like standard zinc-oxide compound, performs like standard zinc-oxide compound, cleans off of the CPU like standard zinc-oxide compound, and only contains 2.4 grams in a tube marked with a net weight of 3 grams, I will believe it is 75% to 80% pure silver because the package says so.
Now if someone can just explain how the
Titan, Stars and CompUSA compounds can all be in the same small syringe, all contain the same amount of compound (They are all full), all weigh the same, all look exactly the same, all feel exactly the same, and all perform exactly the same yet be 10% silver, 25% silver and 85% to 90% pure silver respectively.
Oh, and FlyGuy, the Antec vehicle would have to be much lighter than silicone not heavier. They would have to be using a vehicle with a specific gravity below 0.7 for the numbers to begin to work out. I already used a low specific gravity silicone in my calculations to give them the benefit of the doubt.
And I guess I need to get my scale fixed. It is accurate when it weighs Arctic Silver compounds, Nanotherm compounds, Radio Shack compound, Titan compound, Stars compound, and CompUSA compound since they all match or slightly exceed their specified weight and accurate when it weighs the 1 gram, 5 gram and 10 gram reference weights, but horribly inaccurate when it weighs the Antec compound. Any scale repair techs out there that can help me with this.
