- Jan 13, 2018
- 57
- 0
- 11
Hi all.
I have some basic knowledge and have done repair tasks on my notebook computer in the past.
I'm considering building a desktop, because I can't find it at the price I expect.
I want it to be mini, fanless, and powerful enough for occasional video editing.
So I figured the CPU X i5-8400T Ryzen 5 2400G is probably the proper one.
Any help is appreciated.
1. What YOUR PC will be used for.
Personal daily use and occasional video editing.
2. What YOUR budget is.
Seeing the prices of available PCs (from China), I expect it to cost me around $400.
Example: Partaker B16 Fanless Mini PC
3. What country YOU will be buying YOUR parts from.
I buy online, so mostly China.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
I can buy from the US or China. For China, AliExpress.com (or eBay) is what I use to buy from any vendor.
5. IF YOU have a brand preference.
Linux compatible components.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No.
7. IF YOU plan on overclocking or run the system at default speeds.
Default.
8. What resolution, not monitor size, will you be using?
1080.
9. WHEN do you plan to build it?
ASAP.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No.
No.
Default.
1080.
ASAP.
No.
