If multi GPUs are as bad as people say, maybe a water cooled GTX 780 would be a good choice. Assuming that the GTX 780 is GK110.
If running V-Sync and limiting FPS at 59 with RivaTuner, is there any reason to run RadeonPro? Also, what is the purpose of turning on V-Sync if one is already limiting the FPS to the monitors refresh rate?
Thanks for any help/info. I've been mining with a 7970 crossfire setup for a while now and have decided I want to play a game or two.![]()
He said V-sync is on, and limiting FPS to 59 with rivatuner.
Titan is not as fast as 680 in SLI and you can't count on OC. Some don't OC almost at all like mineI 2nd a Titan. Overclock it and it will be like an SLI 680 but much smoother.
Are you planning to stick with Sandy Bridge or were you going to upgrade to Haswell in another month?
How much are you looking to spend on the board?
*cough* You should use it in your x4 slot to mine while you wait for Haswell and a CF fix. *cough*
Otherwise grab a cheap z77 if you don't care.
http://www.newegg.com/Product/Produc...82E16813157330
Titan is not as fast as 680 in SLI and you can't count on OC. Some don't OC almost at all like mine. I don't think it will be smoother then SLI680 considering that it delivers less fps. The biggest advantage is that you don't have to wait for drivers to support SLI in a given game.
My worry is that the second PCI-E slot on this motherboard is 4x so it would starve a second card. It might make tri fire out of the question too.
Edit: I saw that you updated your post. Is the 7990 that poorly priced? I mean, it's two 7970s with a great game bundle.
If you put the 7950 in the 4x slot it will have MORE than enough bandwith. Even if you are running PCI-e 2.0 x4 is plenty, even for dual GPU cards. Linus ran a 6990 at PCIe X1 speeds and say less than 5% performance decrease..............and thats a dual GPU card.
