Computer Case with 400W Power Supply - $26 Shipped
Originally posted by: alyosha
Originally posted by: Lars
Originally posted by: geoff2k
I can't seem to find any shots of the inside of the case. Got any handy?
I do not have any inside pics of that case right now. The only pics I have of it are
HERE (I modded that case a little)
Lars - great mod, congratulations, sorry to see that mobo's power cord to go across the CPU fan, (damn Abit?).
Thanks. Yeah, I still do not know why this MB is designed like that (Soyo KT333 Dragon Ultra).
Think I'm going to get one of these with the front USB
Anybody got a pic of the case with the front USB?
What about the question concerning the usb, anybody just plug it in and it works?
Thanks 😉
Originally posted by: lsman
Have not fully set up the computer yet. But i find the print out of the USB connector kinda odd. (given past exp with firing the USB connector, i now always double check...)
the USB (both color and print out) is wrong saying: +5v, +D, -D , G when usually most design are +5, -D, +D, G.
anyone plug in and no problem?
info on color and rest.
they sell whatever case they have access to. So you (Wiz) may not get the exact same case as other.
I did check the USB connectors and they did is wrong with the color. (but not wrong will the orientation). The bottom line is start with the red wire (5V) and forget about the miscolor of the green and wire. Then use the black as ground.
For USB on the board, you have to check what you board call for. check the above link for different kind.
Most board will follow example C but some use D.
LARS don't know whether to thank you or not. Temptation!! Temptation!! Resisted this deal until today and finally broke down and ordered one with front USB's. I know its a good deal but now I have to figure what to do with it. Think I can upgrade my oldest system with the extra's laying around the room.😀
i bought the comet case w/300w psu as soon as i hooked everything up the psu died and had to take the one out of my old case
i was going to rma it but they wanted me to ship the whole thing back and pay the shipping so i just kept it.
I paid extra to get the front USB, but it didn't come with it. I am gonna ask a refund for that. It comes with a Duro 400w PS.
I am running it with AMD 1600+ and ECS K7S5A mb. THe OS is win2000. But the machine crashes whenever I am installing Nero or Mozilla. It just reboots itself.
ANy one got a similar problem? Is this a ECS mb problem or the ps problem?
I have installed Nero with no problems on my k7s5a. The again, that doesn't mean it's your PSU. There could be other problems. But if I was asked, no, I wouldn't recommend using that Tigerpro with the k7s5a.
Mid ATX 400Watt Case
Model # LT-A06
Dimension (DxWxH) 18 x 7.5 x 16"
Drive Bays 4 + 2 + 1
Motherboard Micro ATX, ATX up to 10.5X12.5 inches
Expansion Slots 7 Full Size
Switching Power Supply ATX 400W* P4 STYLE P4 CONNECTION
Cooling Fan Front ONE & Rear ONE (Optional - Not Included)
Description Ideal for P3/P4, AMD systems *Total of 7 bays
1 (one) Year Warranty
Not a bad deel but seraching the web in general, there are better deals.
seems to be good price. How's the powersuply. Iwant to use it with my AMD XP 1800+, DVD, CDRW, 2 120GB HD, FD, 3 case fans and 1 CPU fan
what's Tigerpro ?
I am going to upgrade the bios to see if it helps.
It's the cpu cooler problem. The cpu temperature was like 70c. After I changed the cpu cooler, it doesn't crash.
I had a similar problem in the past with ECS K7S5A mb. It would reboot itself just after logging in windows xp.
The problem came from the SDRAM slots; I was using two memory sticks.
I kept only one stick (in the slot that is closer to the CPU) and that fixed my problem.
Hope it helps.
Originally posted by: kbaxter
Thanks!
I promised a daughter that I'd build her her own PC if she got good grades this year. I've got most of the parts, but still needed a case. How timely...
just curious how old your daughter is? =P she should build her own if she's old enough =P
And also, I don't think you should be bribing her to get good grades...it doesn't quite work =P
