Computer Case Poll
Where do you keep your computer
  • On top of the desk
  • Under the desk
how often do you under the desk guys clean your case fans, cpu fans, heatsink, or inside your computer 🙂 ?
Well, my Antec P183 has intake fan filters that keeps a lot of the dust out. I give them a quick go over when I do my weekly vacuuming of my home. About every three months I open up the case and clean up the heatsinks, intakes, case fans and the whatever dust bunnies may have accumulated.
i blow a can of dust off weekly into mine 🙂
whered you buy your fan filters from and what kind you have? i been looking to get many to line my case with
Yeah, I use canned air too. The fan filters are built in the door and came with the case. FrozenCPU has lots of fan filters. I'm sure there are other sites as well.
I got the coolermaster HAF932 im looking for a fan filter for the GINOMORMOUS opening in the side, and one in the front as well as the slot bays 🙂
i had another case that had mesh stuff in the bay slot ports and on the fan filters, ill have to take a pic i cant find it online its ideally what i want to buy
its somewhat like an air conditioning filter if you know what i mean
i just dont want something that will actually lower the airflow through these holes :S i guess i need to research some more
Seems you're not alone in wanting a filter for that 230mm monster. I did find THIS on FrozenCPU. It's a 250mm filter that mounts magnetically.
what im worried about with these filters is the amount of air thats not going to flow through 🙁 or maybe these fans dont have enough intake/exhaust power to be choked by the filters
either way i need alot of filters and alot of materials ^^
the front part of the case has a grill outside the fan which would need a long mesh strip, i got the side panel thats about 1ftx1ft and i got the top and bottom and back where the exhaust is :S this might not be cheap lol
edit - lol didnt even see it was 17.99 ^^ looks like the h100 cost me 130(because i overpaed in store no patience for shipping ) and the filters are going to run about 100 lmao
