guidedbyechoes
I estimate it costing 701 after rebate.
Looks pretty good. I was told the i5's from intel would blow the amd's out of the water for gaming though...
They do, but the GPU is more important. If you were to add $100 for an i5, you would have to subtract $100 from the GPU, leaving you with a much weaker gaming machine overall.
Can you link to the cooler? Some of the super cheap ones are actually worse than the stock AMD.
Of course, feel free to post here if you run into any problems during the build.
Yeah, I think I would forget that one and stick with the stock AMD cooler. The actual heatsink part is TINY!
AHCI is not legacy mode, it's the new standard. The controllers could have defaulted to RAID, which does need extra drivers.
What did the problem turn out to be?
EDIT: What's a dangling? 😱
It only runs in ide or raid.
The ASRock 970 Pro3 absolutely does AHCI mode. Check out page 52 of your manual.
You can save some $$$ by getting some stuff from the Anandtech Forums For Sale thread here.
Don't forget your OS, case and power supply.
I tried running it in ahci but the computer just isnt having it. What are the benefits if I don't plan on using win 8?
