Fritzo
- Jan 3, 2001
- 41,920
- 2,161
- 126
I'm size 12 and a B width. Try dealing with that. Uhg.
I'm a 13 wide.
1) Please never call them tippy toesYou know how when you stand on your tippy toes your whole shoe is supposed to kinda conform to your foots shape and whatever... well, with some shoes the back of the shoe just doesn't come up with me. Instead, my heel slips out of the shoe entirely or just some of the shoe. This could be because of bad sizing, but I am wearing some shoes that are definitely quite small/my-size-maybe-small-even and it happens with those.
Any ideas how to fix this? I can only find products for womens high heel shoes from Google searching. Figured ATOT, the true omnipotent source, would know how to solve. I'm talking about dress shoes btw.
Thanks
I guess this would be too obvious.
Converse and Nike's are not true to size. There is even variation between shoes of the same brand. Jack Purcells and Chuck Taylors are sized differently, for example.
Quit wearing high heels.
I used to be a 10. Now I'm probably a 9. Now I'm reconsidering and thinking I am more likely an 8.5 or 8. Which is weird because my Nike's that are 10s seem fine. I have converse that are 9s and feel large though. (Like my toe's aren't hitting the ends properly)
Fixed. Many manufacturers use different lasts for each model. You really need to try on the exact shoe you want to buy, or a similar shoe made on the exact same last.That's not that weird. I wear a size 11 tennis shoes, a size 9.5 dress shoe and a size 9 bowling shoe. It also varies a bit by shoe model.
Aren't you tired of seeing Froot Loops?I'm actually curious to see what Trident's feet look like now.
how else will I look fabulous and make my ass look good?
I'm not sure if I have the wide foot problem. It's hard to tell. I'm definitely losing my manliness though in this whole situation.
Those always leave a nasty sticky residue.you can find theses in most grocery stores
http://www.amazon.com/Dr-Scholls-Hee...1833675&sr=8-3
I've used them w/ some success w/ shoes that didn't fit quite right...if nothing else it will help w/ blisters from the rubbing, but also makes them a bit more snug.
I've got narrow feet/heels and this is what I do:
http://www.runnersworld.co.uk/shoes/how-to-lace-your-shoe/482.html
