dullard
- May 21, 2001
- 26,066
- 4,712
- 126
I'll throw in a twist. Suppose the drinks were hot and the spoon was room temperature (quite a reasonable assumption). Suppose you did the transfer and mixing in typical amounts of time (ie you didn't take an eternity for either step, also quite a reasonable assumption).
The result: the spoon probably expanded from the time of the first scoop to the time of the second scoop since it heated up more during the mixing than it had during the first dip into the first cup (almost all spoons would be made of materials that expand with increased temperatures). Since the riddle said the spoon was full, you transferred more material in the second scoop.
With that reasonable twist, you transfer more tea to the coffee than there is coffee in the tea.
