futurefields
get a life, stop wasting my time with these pointless replies
whats up with the load times for mp maps?
seems a bit long
Another excellent console port. If you select a widescreen resolution (non 16:9) it just stretches the image to fit the screen.
Greatly depends on your load settings (if you pre-fetch shaders) but I've found that it's only longer for the first map, and then subsequently, everything loads faster.
That probably has more to do with not wanting anyone to have a wider viewing area for fairness reasons in multiplayer than quality of the port. At least they gave the pc FOV adjustment right out of the gate this time rather than waiting months to fix it, then retro banning people who were using the FOV changer.Another excellent console port. If you select a widescreen resolution (non 16:9) it just stretches the image to fit the screen.
