SerpentRoyal
Banned
IP35-E is a better board, but it's no longer cheap.
Originally posted by: VirtualLarry
Originally posted by: SerpentRoyal
The HP/Crucial RAM is $ in your pocket.
Not necessarily. I sent my rebate in during 10/2007, and still haven't received it yet.
Originally posted by: chuckm
I believe the IP 35-e is in short supply and maybe gone all together. I haven't checked for about a week, but the only place I saw it was directron.com Good luck
http://www.directron.com/ip35e.html
Available now @ NewEgg for $90 plus $7 ship.
Originally posted by: quadomatic
Its just what I've been told, but SerpentRoyal did a review of it here:
http://forums.anandtech.com/me...=2063989&enterthread=y
It's been shown to give pretty good results for oc'ing the E21xx series too:
http://forums.anandtech.com/me...=2099932&enterthread=y
On another note, I took another look at some ram, since I don't think I'd go for the HP Ram, because it costs too much before rebate. Also, the retailers, except for costcentral, all seem to be a gamble on reliability. Can someone tell me which of these is best? I'd be going with the IP35-E or the Gigabyte DS3L. All are 2x 1GB stick sets:
Crucial Ballistix DDR2 667: http://www.newegg.com/Product/...x?Item=N82E16820146567
-$41.99 after $15 MIR
Kingston DDR2 667 http://www.newegg.com/Product/...x?Item=N82E16820134046
-$38.99
Kingston ValuRAM DDR2 800 http://www.newegg.com/Product/...x?Item=N82E16820134117
-$44.99
Mushkin DDR2 800 http://www.newegg.com/Product/...x?Item=N82E16820146118
-$49.99
The Kingston DDR2 667 for $38.99 seems like a good deal.
Run well at default settings and 1.8V DDR2 667 or 800 RAM. Can easily overlock any Intel CPU up to 500MHz FSB. Can control the speed of 2 wire and/or 3 wire fan based on CPU or SYSTEM temp. You may need 14 BIOS if you want to run 45nm chips. I didn't see any FSB hole with my E2140, E4300, and E6320 from 200 to 490MHz FSB.
There's a big thread about IP35-E @ MB forum. IP35-E is basically an IP35 Pro minus 1394a, SATA, RAID, and extra SATA ports. It's the best sub $90 overclocking board today.
-$38.99
-$44.99
-$49.99
How far do you want to overclock? Kingston N5 DDR2 667 is the best deal if you don't need to push the FSB speed above 400MHz. Note that the N5 DDR2 400 is only $6 more, but should be able to run @ 450MHz. These chips do not come with rebate.
Thanks for the info. Have read several posts declaring the Abit board to be better but no body had given a reason for that opinion. The only discernible difference from the Newegg spec lists was an extra PCIe 1x slot and 4 more USB ports on the Gigabyte board.
From your list of positives for the Abit board, the 2 wire fan speed control is the only one that I wish were a feature of my P35-DS3L. However I quite quickly settled into a 8x400 overclock with an E2180 thus never explored the upper FSB limit nor tried enough combinations to see any FSB hole the board may exhibit.
It appears both are strong performers and good bargain boards for the overclocker.
ENJOY
-$38.99
-$44.99
-$49.99
I was hoping to overclock to at least 3.2 ghz on a E2160 on the Abit IP35-E or the Gigabyte DS3L, but I'd like to push to 3.4/3.5 if possible. Which ram would I need to do that? What processor would you recommend for that as well? I'm trying to spend less than $200, but that seems unlikely what with the cost of the motherboard being $90. If I could save on that, I would, but I don't think I can get a good overclock on a cheaper motherboard.
Also, what do you think about buying a used motherboard and used RAM? Do you think that would cause me any problems?
Where can I buy the E2160 for $60? It's $80 on Newegg.com
Just ordered the Hyper TX2 Cooling Fan. I don't want to miss out on $20 savings.
What is the receipt they need for the rebate? Is it the page you go to after you buy, or is it the invoice in the package you receive?
So, right now, since I can't find an IP35-E, I think the specs would be as follows:
Intel Pentium Dual Core E2140 - $65 from Micro Center (tax included)
Gigabyte DS3L Motherboard - $90 w/Free Shipping from ZipZoomFly
Cooler Master Hyper TX2 CPU Heatsink/Fan - $7.83 Shipped from Newegg.com (after $20 MIR)
2 GB HP Ram - $15 (after $40 MIR), various stores
So I'm hoping the total cost will come out to: $177.83-ish, $237.83 before rebates
If anyone has anymore advice on saving money on this system, that would be much appreciated. I'm going to keep my eye on TheNerds.net. Hopefully they'll get more in stock soon.
