CHHCaptain(380X?) power Preview
RussianSensation
19,458
765
What I meant was that if AMD's GCN 2 is inherently not much more efficient than GCN 1.1/1.3 and it relies on a node shrink to compete, it will not be good for AMD when NV and AMD are together on the same node. Node shrinks as you all know will be infrequent moving forward and we're likely to be stuck on one for much longer.
AMD may have a head start and look really uber, but when NV catches up and remains on the same node for a few years..
I am somewhat disappointed the architecture itself isn't massively more perf/w, that is all.
It would give AMD another 1.5 years to revise their GCN 2.0 to 3.0 and focus on improving perf/watt of the architecture while they wait for 16nm. It's possible that moving to 20nm + HBM + a 2x more efficient perf/watt "28nm architecture" is simply too much at once. Who knows, as I am not an engineer. If NV doesn't go 16nm for Maxwell and sticks to 28nm until Pascal in 2016, then AMD's gamble with stop-gap 20nm will have paid off.
Also if NV ever manages to sell the idea that AIO water cooling is inferior than a noisy blower or open air design that dumps heat in your case requiring even more fans for case airflow.. I'll ROFLMAO.
It would take a very "special" consumer to believe that.
Oh but they will. Didn't you already see some gamers opposing AIO high-end cards? If 390X uses 50W more power on a 350W system than a GM200, it will be brought up. hehe
I love the idea of going with AIO for reference for HIGH-END cards. Who the heck buys a beast of a GPU without having a case that has a 120mm slot? Water cooling by default is a damn win for gamers. All that heat, out your case, you don't need to install extra fans, you use the radiator fan as exhaust. Two birds, one fan.
Me too. 2 cards in CF/SLI max overclocked at 80-83C with all the heat leaving your case, minus the noise of reference 290X/980s at 100% fan speed. EPIC win.
If only AMD introduced a flagship card with faster performance than GM200 and superior performance/watt, I want to see the response of NV users as to why they still aren't switching to AMD. :D
This thread just keeps on delivering...go RS.:thumbsup:
and thanks for the Chiphell link raghu.:)
You really ought to thank raghu and Silverforce for following the news that closely instead of me :)
The only possible negative I can foresee if 390X being limited to 4GB of VRAM.
n0x1ous
2,574
252
While I agree that reference AIO is a good idea, putting 290x and 980 reference blowers on the same plane is a bit of stretch RS. nvidia reference design does a good job (obviously not as good as open air but for what it is its quite good) whereas the 290 reference is intolerable.
raghu78
4,093
1,476
We don't know the full gamut of architectural and chip improvements on R9 390X aka Bermuda XT. If the process is GF 28SHP as I suspect then a 60 - 65% improved performance without a full node shrink is commendable. AMD will have further improvements over 2015 and 2016 to counter Finfet Maxwell and Pascal. I don't expect Pascal to turn up before late 2016. Nvidia would want to reduce their risks when moving to 16FF+. So the first 16FF+ chips will be a straight doubling of GM204 specs on 16FF+ - 4096 cuda cores with 128 ROPs and maybe a 384 bit bus. Pascal brings a whole host of new tech - first grounds up DX12 architecture, HBM, 2.5D stacking , NVLink. So there is no way Nvidia is going to attempt Pascal on a bleeding edge node which usually has yield challenges.
You can bet a whole host of R9 290X owners (and maybe even 780 Ti / GTX 980 owners :D) are going to move to Bermuda. good for those who waited. :thumbsup:
Don't you know the response already - Physx, Gameworks, Hairworks, TWIMTBP, DSR, Gsync, drivers etc . But the fact is AMD has as good or even better reasons - Mantle, XDMA CF, Tress FX 3.0, VSR, Gaming Evolved, Freesync :D.
As for 4GB VRAM should not be a issue in the short term (12 - 15 months). AMD has to wait for HBM2 to bring 8GB / 16GB flagships by mid - 2016.
http://pc.watch.impress.co.jp/img/pcw/docs/646/660/html/13.jpg.html
RussianSensation
19,458
765
Ya, I agree and I didn't mean to compare them directly. I meant to say that both are inadequate in SLI/CF without increasing fan speed to nearly 100%.
"This is the first time we've seen the real-time in-game clock speed clock throttle below the boost clock in SLI in games. It seems GTX 980 SLI is clock throttling in SLI on reference video cards."
http://www.hardocp.com/article/2014...980_sli_overclocked_gpu_review/2#.VJA0ayuUfsc
And that's just with 180W cards!
As you go higher in TDP to 250W, the Titan cooler's flaws only become worse as temperatures and noise skyrockets and your reference blower is going at 4000 rpm fan speed to maintain stability and clocks.
http://www.xbitlabs.com/articles/gr...te-geforce-gtx-titan-black-ghz-edition_4.html
Honestly, I just look forward to strong competition from both brands as I don't like this idea of $550-600 980 against a $300 290X for 20% more performance. I want the old days of X850XT vs. 6800U and 6800GT vs. X850Pro. Basically either option delivered great price/performance, regardless if you went AMD or NV.
n0x1ous
2,574
252
Honestly, I just look forward to strong competition from both brands as I don't like this idea of $550-600 980 against a $300 290X for 20% more performance. What non-sense.
Agreed - I'm excited by this Chiphell leak because they are pretty reliable. Curious to see how much the reference AIO will add to the cost. Certainly less then the extra $100 per card I had to spend on Corsair HG10's and H90's for my 290 CF
Feb 19, 2009
10,457
10
A 120mm AIO (Asetek models rebranded into whatever) sold in bulk to retailers at cost is ~$28 AUD from my own experience.
raghu78
4,093
1,476
If that performance turns out true AMD will have no problem getting USD 650 for Bermuda XT from enthusiasts. Everyone will be willing to pay that as now you get a GTX 980 which is much slower for USD 550.
My predictions are
Bermuda XT - USD 649 (40 - 45% faster than GTX 980)
Bermuda Pro - USD 499 (30 - 35% faster than GTX 980)
Fiji XT - USD 399 ( 15% faster than GTX 980)
Fiji Pro - USD 299 ( 5% faster than GTX 980)
AMD will return the favour to Nvidia by forcing Nvidia to gut their prices as they had to do when GTX 970 launched :D
RussianSensation
19,458
765
No way. 70% of $300+ market (i.e., 970/980/780/780Ti/Titan) users will wait to Pascal or GM200. They won't buy AMD. :sneaky:
Hexus has an article on AMD's next cards:
"According to reports, which have a mostly-reliable track record for AMD leaks, there will be a two-part response. First, AMD will launch a faster revision of its GCN Hawaii architecture that takes advantage of a matured manufacturing process, and this is slated for an early 2015 release. Then, during summer of 2015, AMD will, if predictions hold true, launch a new series of GPUs with the codename 'Caribbean Islands.'
The launch window for Caribbean Islands is subject to change at this early stage, of course, though a launch between June to August is most likely. Other details about Caribbean Islands graphics cards, such as whether they will make use of a 16 or 20nm process, are not known. AMD may reveal more information during its investor relations conference in February 2015 but between now and then the descent into the speculation quagmire begins."
http://hexus.net/tech/news/graphics/78189-next-gen-amd-graphics-codenamed-caribbean-islands/
So similar to HD4870->4890 stop-gap (Hawaii Rev 2) and then full blown 5870 (390X). That would suck if 390X isn't out until June-August 2015.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
The stop gap may force Maxwell big die out of hiding. Oh man, I can't afford this stuff anymore. I may just sit on the sidelines and watch for now.
AnandThenMan
3,991
627
Edit: One thing that isn't great, is that AMD gets these gains by going to 20nm to combat NV's Maxwell on 28nm so it isn't a fair fight. What happens when they both duke it out on 16nm finfet for example. AMD definitely needs to improve the architecture efficiency itself, without reliance on jumping to the next node earlier to compete. :/
I guess I'm in the minority but I think this is a very valid concern for AMD.
n0x1ous
2,574
252
Its valid but if they fix the reference cooler by going AIO then I don't care how much power/heat etc. Bring it on AMD - my wallet is ready!
krumme
5,956
1,596
If it is 20nm its good news because it means gf is starting to perform. It means a lot for competition and better perf for us consumers on cpu, apu, mobile solution, leaner consoles and... gpu.
I mean as gpu perf goes who cares that much how the perf got there. It might be hbm, process, arch. But a new node benefits all.
caswow
525
no its not. its a matter of priority. nv could have gone 20nm too. i doesnt matter how something is achieved. as long as the price and perf. is right nobody has to care how this was done.
raghu78
4,093
1,476
did you see the source whom hexus is quoting. the internet trash site called fudzilla. they are as good as wccftech when it comes to information. both are bottom of the barrel click bait rubbish sites :D
there is no point in releasing a hawaii refresh. think about it. why would AMD need 15+ months for a freaking die respin especially when the next gen GPU architecture with a state of the art memory system is ready in the fabs. For a cash strapped AMD they have to be very prudent with capital investments. So anybody with common sense will know AMD will not release a Hawaii respin.
btw you have to realize that with 2.5D stacking depending on the foundry the final assembly can happen in house, like in the case of TSMC which is a one-stop-shop turnkey solution or it can happen at the OSAT partners, like in the case of GF. GF's OSAT partner is Amkor.
http://en.wikipedia.org/wiki/Category:Assembly_and_Test_semiconductor_companies
http://en.wikipedia.org/wiki/Amkor_Technology
http://www.amkor.com/index.cfm?objectid=E6A2243B-0017-10F6-B680958B1E902E87
So GF has to fab the die and pass it on to the OSAT partners for final packaging on silicon substrate with HBM stacked memory dies provided by Hynix. The production timelines are longer and so actually for a Q1 2015 release the actual production GPU chips should be ready by now. The fully qualified engineering samples must have been ready atleast 3 - 4 months earlier or even more given the challenges with a new production process (2.5d stacking on interposer) and HBM.
You realize that other than Xilinx which has used 2.5D stacking in low volume high cost FPGA products no one has yet manufactured 2.5D stacked products in high volume.
https://semiaccurate.com/2012/09/05/hot-chips-talks-all-about-chip-stacking-good-and-bad/
http://semiaccurate.com/2012/09/06/die-stacking-has-promise-and-problems/
AMD,GF,Amkor and Hynix had 2.5D stacked prototype chips in 2011. But its taken 4 years for AMD,GF,Amkor,Hynix to bring this technology to high volume production GPUs and resolve the related manufacturing challenges.
http://semiaccurate.com/2011/10/27/amd-far-future-prototype-gpu-pictured/
http://sites.amd.com/la/Documents/TFE2011_001AMC.pdf
http://sites.amd.com/us/Documents/TFE2011_006HYN.pdf
clueless people like fuad will come up with ridiculous trash and call it "news from industry sources/contacts".
WittyRemark
118
My gripe with this is that my case (Fractal Define R2) doesn't offer much space behind my NH-D14. I'm not sure if a Radiator + fan fits in there and if yes it will get the hot air from the CPU. The Define R2 has a 120mm side vent which could be used. But for cases that don't have a side vent cooling the GPU with hot air from CPU doesn't make a lot of sense?
There'd be plenty of non-reference Air cooled designs (e.g. sapphire vapor X).
kawi6rr
567
156
You would think by now most computer savy individuals would know that but it seems certains "savy" individuals keep referring to the reference design.
96Firebird
5,746
342
Hopefully this time AIBs have their non-reference designs ready on release. It took over 2 months, if I recall correctly, for open-air designs to come out for Hawaii. By that time, mining had increased their prices and I was no longer interested.
raghu78
4,093
1,476
If the reference Bermuda XT and Pro uses Hybrid AIO cooling then AMD reference designs should sell very well. What AMD needs to make sure is they have sufficient production volume and supply to capitalize on the demand.
AMD should know by now if they have a winner on their hands. So the key here is meeting the market demand. AIB designs with open air coolers can arrive after a couple of months, but in all fairness should not cost more than the reference AIO design. I am thinking AMD will price the R9 390X at USD 650 as it seems to have what it takes to compete with big Maxwell.
96Firebird
5,746
342
Yes, but not everyone wants a water-cooled card, for various reasons. Better to have more options right away.
