CHHCaptain(380X?) power Preview
Petrelli
That's the point. If the leak was from anyone else, it would be too easier to dismiss. But ChipHell was THE only site wth 3 consecutive generational leaks that were pretty damn close: Tahiti’s preview launch numbers (7950/7970) and even the most recent Volcanic Islands R200 series and Maxwell GM204 launch turned out to be quite accurate in terms of the performance numbers. Actually the GM204 leaks were underclocked engineering samples and the final cards performed even better than the leaks from ChipHell.
I think people fell for the GM 204 hype. While Maxwell is undoubtedly an awesome architecture from a perf/watt point of view, 970/980 aren't that awesome performance wise vs. 290X at high rez gaming.
If AMD bumps performance just 30-35% over 290X, you are already 15-18% faster than the 980. NV's 970/980 look really good because of the negative stigma of reference 290/290X, and because they are new tech with newer features and less power usage. As far as performance goes, they have hardly moved the bar. NV's performance also looks much better at 1080p/1200p/1440p which are the more popular resolutions.
NV hasn't even shown off the big guns. They are just milking the mid-range GM204 until they have to release 780/780Ti successors. I think 390X would need to be 25% faster than a 980 to compete favorably against the lower SKU of GM200. There is a lot more pressure on AMD with 390 series because let's face it 970/980 are really 960/960Ti. :D
Sounds hard to believe without 20nm + HBM + very large die -- a trifecta very unlikely this early in 20nm cycle. If true, it would sell out right away.
380X is 28nm
MrK6
4,458
4
The 970 is popular not only because it's fast, but also because it's only $330. We haven't seen bargain chips like that in awhile. In comparison, the 980 is a poor value and a halo part; it's there for people who like to spend money on computers. Therefore, it would be wise for AMD to release a solidly outperforming part at a similar price to the 980, and offer a cut down version to compete against the 970. If this happens I might upgrade from my 970.
I'm in the same boat. They've had a good track record which means I'll be paying close attention with wallet in hand come Q1 2015 (February last I heard).
krumme
5,956
1,596
Ok so if chiphell is right at least perf/watt improves even slightly beyond nv. If thats the case doesnt that imply something new besides the hbm? Voltage regulation tech ...? I asume its still 28nm. What about gf soi?
geoxile
327
25
digitaldurandal
1,828
If this is true and launches for 350 or less with 4gb RAM I will be trading out the 290s I just got sooner than expected. Which is fine since I got 4 games with them that I wanted and 2 for 500 anyway.
skipsneeky2
5,035
All i care about is it being faster then a 980, performance needs to move forward.I'm not a hippy who needs a 150w tdp card that runs faster then a 970 while giving you butterfly kisses and a diet coke.I just want 980+ performance.
krumme
5,956
1,596
Lol - yeaa. We need some serious punch now at least 30% plus 980 or its a shame. Whatever it takes if its 150 or 300w. Gaming is about performance. What i would like though is the ability for the cooler to be turned completely off when not gaming as we have seen from some 970 cards eg msi.
3DVagabond
11,951
204
You can keep your fingers crossed. AMD has been known to do such things. I wouldn't count on something that's ~15% faster than 980 for the same price as a 970. You might be asking for too much. At least at first.
Fire&Blood
2,333
18
:biggrin:
While I do have a 970 on the way for my HTPC (long story short, it's the only card that fits the case) I agree with this.
I wouldn't mind efficiency taking the backseat for performance parts, I'll build a 4K system once SLI/crossfire can handle it without major compromises that are necessary now.
skipsneeky2
5,035
:biggrin:
Yeah the 970 really is great for htpc,that new Asus mini is just awesome.You won't be seeing a 290/290x ever in that size period.
I could see power being just a issue for perhaps a select few but i bet there is more then enough people hardcore enough to put up with a gtx480 2.0 type card if it manhandles these new hippy cards.
Like anyone spending $400+ on a gpu seriously gives a rats ass if the card consumes 20w more then another one,there is so many recommendations for the easy bake oven 290 right now that i am ready for the big boys,bring out the 300w guns.
Fire&Blood
2,333
18
That's what I'm waiting for, thinking that WIN 10/DX12+evolution of DDR4+Skylake will make it easier for 2x ~$500 GPU's to get 4K done.
I honestly didn't even factor in the efficiency of the 970 in the purchase but heat output+cooling solution=physical dimensions aligned it with my quest for a best performing, < 10.3" length GPU.
I have a "manly" HAF X here already waiting for these things to happen.
If that means I am looking for a pair of 300W ovens doubling as GPU's, so be it.
skipsneeky2
5,035
Purchased a 7850 a while back basically with the same exact goal as you,pretty awesome card for the time.It was a MSI TF3 which sat at a lovely 7.76'' long. Pretty much fit in the Gateway DX4200 case i had at the time like a glove.
I cried like a baby when it shorted out and died on me, eventually grabbed this Zotac 770 right before the stupid 290 debuts and had to beat the living hell out of a hard drive cage to get it out of the DX4200 case to fit this monster. Eventually cut the mesh off the side of the case and slapped on a 140mm fan till i just replaced the entire case with a Rosewell Line-m.:p
2,012
These benchmarks and power consumption numbers look very competitive; more efficient than even GM204 if true.
Feb 19, 2009
10,457
10
GCN 2 needs to beat Maxwell on efficiency if AMD hopes to recover the all important notebook marketshare.
On the Desktop, that efficiency gain would be best put to use with a more aggressive Boost system to extract more performance.
If GCN 2 lacks efficiency, it really is all over for AMD. They won't be able to stay relevant with another architecture generation and many years of eroding marketshare.
2,012
Even parity would be a good start, especially as they're both on the same manufacturing node. NVIDIA has been touting notebook gaming growth for quite some time; I have long suspected that the efficiency focus we saw with Kepler and continuing into Maxwell is due to the company going after notebooks and HPC as the primary design targets -- both markets that highly value power efficiency.
The benchmarks here suggest that AMD has indeed delivered on actually beating NVIDIA on power efficiency. I'm very interested to see how the chips perform once they're launched.
garagisti
592
7
I think AMD was bleeding market share even when they had better, more efficient designs. It will be nice if AMD once again comes up with something more efficient. This chip is quite promising, but AMD may keep losing notebooks though I think a reversal in desktop may happen. It can't come soon enough for both AMD and customers.
dacostafilipe
810
315
If this is a 380X, it will not be enough to beat nVidia on fastest single GPU. There's still the 980ti and a future Titan ...
A possible 390X could beat a 980ti, but I don't think it would be enough for the next Titan (I still expect it to have a AIO Watercoler).
Could AMD pull a Titan with the 295X-like cooler we saw some time ago? How about an "AMD Radeon Olymp" (you know, those who vanquished the Titans in the Greek mythology) :biggrin:
Feb 19, 2009
10,457
10
During the 4800 and especially 5800 series, AMD had much better marketshare, particularly dominating on notebooks. Efficiency matters a lot in those markets.
RussianSensation
19,458
765
AMD already missed 2015 for major notebook design wins. 860M/970/980M will dominate notebook sales. Even if 300 series beats Maxwell in perf/watt, the next time AMD will be able to bid for major wins is for 2016. Being late and not showing up at all (HD8000/200M) is far worse than being behind in Perf/watt. There were plenty of excellent HD8770/8790M and various Pitcairn designs that were head-to-head in perf/watt against mobile Kepler but it didn't matter since AMD was so late with their launch, all the major designs were won by NV by default of AMD not bidding with GCN, relying on ancient VLIW chips.
Right now AMD lost the 2015 laptop market completely. Their best hope is to have an efficient GCN 2.0/HBM design ready as a foundation for 2016 product stack.
raghu78
4,093
1,476
How do you conclude that AMD missed 2015 for major notebook design wins. As long as AMD has next gen R9 3xx notebook chips sampling to OEMs by Q1 2015 and ready to launch by Computex 2015 they are well in contention for 2015 notebook design wins. btw Broadwell notebook chips are not shipping till early Q2 2015. Given that Intel will be ramping 14nm throughout 2015, the next gen R3xx chips with HBM can definitely land in premium gaming notebooks. We will know by Computex 2015 if AMD has made progress in notebook design wins.
Being late and now showing at all (HD8000/200M) is far worse than being behind in Perf/watt. There were plenty of excellent HD8770/8790M and various Pitcairn designs that were head-to-head in perf/watt against mobile Kepler but it didn't matter since AMD was so late with their launch, all the major designs were won by NV by default of AMD not bidding with GCN, relying on ancient VLIW chips.
AMD's 2015 R9 3xx products are launching in Q1 2015. I am quite sure AMD can launch notebook chips by Computex 2015 and ready for the key back to school and holiday seasons. AMD's R9 3xx GPU products are most likely built at GF 28SHP. AMD should have enough supply from GF and thus are well poised to gain marketshare in notebooks :whiste:
RussianSensation
19,458
765
^ Look at laptops such as MSI Gaming GS60/70, Maingear, Origin, MacBook Pros or Alienware. They get refreshed 1-2 times a year at the most. That means for the next 6 months, whoever locked in design wins with them won't be kicked out even if 300 series launched January 1, 2015.
Broadwell-K and Skylake are well behind schedule too so it won't be until 2nd half of 2015 most likely until there are new laptops with the newer Intel chips in large volumes. By June 2015, GM204 will be 10 months old which means NV can re-spin a faster version of 970/980M refresh and/or lower prices. Whatever minor gains R9 300 brings in mobile, by the time new gaming laptop designs roll out in 2H of 2015 with Broadwell, NV will have plenty of time to respond and take the wind out of AMD's sails.
OTOH, the desktop is completely different as people don't need to wait until BW/Skylake to buy a new GPU, unlike laptop buyers which might wait for major architecture changes when timing their new laptop purchases. Since on the desktop side NV has still not brought out 960/960Ti or GM200, and they have major holes in their product stack in the $120-300 and $350-500 levels, R9 300 series has a greater opportunity to strike back on the desktop.
I agree that the laptop market is more important for GPU market share but given that AMD couldn't even secure HD7970M/8970M in many high-end Intel-powered laptops, despite both of those chips being extremely competitive in price/performance and performance/watt, AMD's strategy/relationships/approach in getting OEM design wins in the mobile dGPU sector is clearly broken.
raghu78
4,093
1,476
The gaming laptops are updated (and not refreshed) whenever the fastest notebook GPU in the world changes. As soon as GTX 980M launched in Oct 2014 these vendors announced updates to their gaming notebook models. btw these notebooks GPUs are MXM modules (just like desktops have AIB). So its not as if a gaming notebook vendor has specific designs made for a notebook GPU. In fact most gaming notebook vendors offer a host of GPU choices for the top gaming notebooks.
http://en.wikipedia.org/wiki/Mobile_PCI_Express_Module
GTX 980M sure as hell did not launch at the traditional Computex event and missed the back to school season. It made it to the holiday season.
NV have extracted the most they can out of the 28nm node. If the leaked chiphell benchmarks are an indication of R9 380X with 3072 sp then Nvidia has nothing to beat the R9 380X when it launches in notebooks.
btw I am of the opinion that R9 390X, R9 390 and R9 380X are all made from the same flagship GCN 2.0 chip with 4096,3584 and 3072 sp respectively with 4 GB HBM. My reasoning is that a > 500 sq mm die chip at GF 28 SHP would have yield issues as its the first time ever for AMD and GF with such a big die. AMD can easily release lower clocked versions, with reduced voltages and aggressive power binning of R9 390X, R9 390 and R9 380. HBM is a perfect match for low power notebook GPUs. The desktop SKUs can run at 1 Ghz core and 1 Gbps HBM and the notebook SKUs can run at 800 Mhz core and 0.8 Gbps .The bandwidth would be a massive 409.6 GB/s with a 4Hi 4 stack config even at 0.8 Gbps. Awesome for 4k notebook gaming.
Sorry but I think it all boils down to R9 390X vs GM200 and R9 380X vs GM204. I am thinking that GCN 2.0 with HBM is going to bring AMD back into competition in gaming desktops and notebooks. I think you are going to be surprised at how much the HBM time to market advantage is going to work in favour of AMD.
krumme
5,956
1,596
AMD didnt have an fuzfree alternative to optimus until recently. Now they dont have the perf/watt compettitivenes. Besides NV sale and support with the OEM is probably far better. There is much more to it than card performance metrics.
And yeaa even if 390m performs its probably a h2 thing even for the few where the upgrade cycle fits.
skipsneeky2
5,035
Anyone think there is a chance this card could debut at or about $500 and by the end of Q1 2015?
