CASE MODS: Guides/Articles/Supplies/Gallerys/FAQ/AnandTech Users Cases!
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
quickford
30
Is it considered a case mod that I had to use pliers to mangle one of the rivets on the back of the I/O shield to be able to get my AGP card in?
LED
6,127
LOL...Technically yes as any Hard change/differt look from stock/original look is considered 1 Mod !:camera:
LED
6,127
I found some galleries... not sure if these links are a repost or if people have seen them but are too lazy to put em up, but here they are:
Thanks Wex but my ? to you is...Are you to lazy to read this thread to see if the Links were 1 repost? :p:...roll;
Wex
148
I've browsed through this thread... And seen most of em.. i dont recall/remember seeing any of those...and yes im too lazy to go look for em.:D
systema
15
i'm interested in modding my case (dremel work). would anybody suggest a decent dremel tool (around 50 bucks would do)? thanks in advance
ubernym
All right all you modding gurus: I've been contemplating building a pc right into the wall. I know that walls aren't very thick, so this will obviously take a lot of planning. One thing I'm concerned about is cooling. I'm not really interested in just sticking a case into the wall; I'd rather build the parts in and place fans and such strategically throughout. Also, I'd probably put an access panel and some vents on the other side(i.e., I'd have to go into another room, like my utility room, to change out parts). Any suggestions or thoughts on materials that would help this along?
lsman
3,869
www.flickr.com
links on Modding Supplies section to Professional Case Modding Service
are misalign (link the next one instead)
some of them are out:
pcmods -> frozencpu buy it
2cooltek -> gone
pelikan
3,118
I'd cut out a section of sheetrock on the back side of the wall, to the size of enclosure you want. Then I'd add 2x4's (or 2x6's depending on wall thickness) to enclose that area inside the wall. Now you have a box.
Then I'd make a door for the backside of the wall. 3/4" plywood is available with a top laminate of spruce (used for cabinet making) and that paints real well and is very smooth.
I'd mount a motherboard tray or a cut out section of an old case to mount the motherboard on and screw that onto a piece of 1/4" plywood. The 1/4" plywood can be mounted inside the wall to the sheetrock of the front wall- so that when you open the access door you are facing the motherboard. Then cut holes in the front wall and door for fans. The holes can be lined with appropriate sized pvc pipe cut down to 3/4" lengths and trimmed with plastic moulding. You could put filters in there or even trim out the holes with filters.
If you make the 1/4" plywood a little bigger than the motherboard you can cut holes for CD/DVD drives and I/O shield. But your wall will have to be thick enough if you want the drives totally enclosed.
Then you need to run some power in there, or run your psu cord out of the wall. A receptacle box with a cable face plate would work good for that.
PhoenixOfWater
1,583
I havn't really been looking
School killing me :(
And the posting need to be reformated...It like evertime they update the forums it mess with the posting..
cainsdive
238
Good start. Couple of things. You will probably want to do this low down as you will have to have all input/output cables coming out below desk height. Make your cuts in the sheetrock nice and clean as it's a pain to repair. If you have 4" studs (as is normal ) you will have to make the wall deeper. To do this line the cut out with 6" strips of 1/2" ply, yes this will leave some sticking out into your utility room or what have you. Make it the right size and you can stick a standered size cabinet door on it. Door should have holes top and bottom for fans, bottom blowing in top sucking out. The mother board will probibly have it's ports upwardes. In the room that you want to use the comp. cut a hole about 9"long by 6"high. This is so you can plug all the toys in. Remember you are mounting the m/b with ports upward. line out the hole. As for your drives, you probably want to go and cut out a small area of sheetrock and replace it with the same thickness of ply. Run some finnishing timber around that and cut the holes for your drives and your done. :D:beer:
whoboo
145
i would like to say that indirectflow has horrible customer service. i ordered some fans from them, orders are suppose to be shipped out the next day yet i waited 2 wks and havent receive anything yet. so i called them and he told me that it will go out the next day. so i figure everything was good to go. waited another wk and nothing yet so i called them and now they are telling me that its on backorder. a wk ago, it was ready to be shipped out and now its on backorder? how shady is that plus the owner didnt even sound like he wanted my business. not even a sorry for the inconvience.
Cawchy87
5,104
What should i do to it next?????
The case is painted black (originally silver). Custom top window. Custom Cathods.
Front with door closed: http://images.dr3vil.com/uploads/IMG_9518[1].jpg
Front with door open:
http://images.dr3vil.com/uploads/IMG_9519[1].jpg
Side window:
http://images.dr3vil.com/uploads/IMG_9520[1].jpg
Top and side window:
http://images.dr3vil.com/uploads/IMG_9521[1].jpg
Side off:
http://images.dr3vil.com/uploads/IMG_9522[1].jpg
Showing off my video card 8) :
http://images.dr3vil.com/uploads/IMG_9523[1].jpg
My very messy desk (Can you guess i got a cell phone yesterday?):
http://images.dr3vil.com/uploads/IMG_9524[1].jpg
Let me know what sucks and i'll work on it!
My next project is drilling into the side window and putting an 80mm fan.
And after that, the top window... this time 120mm :) .
Mark R
16
Well, it's almost a PC, so it probably can go here.
Anyway, here's my all new modded LuXBOX. I think I've rather overdone it with the LEDs. When you pay $12 each for a blue LED, you'd expect them be good, so I only installed 3. Well, I could probably have done with 1 - but they're superglued in place now, so there's no going back.
Hmm. I think I'd better add a switch.
Locut0s
22,205
44
While Bit-tech has been posted I'm surprised no one has posted a link to the WMD mod on their site. It was posted in a seperate post here a while ago but it deserves to be in a sticky like this:
http://www.bit-tech.net/article/150
This thing is just INSANE!!!
Muse
41,015
10,274
Front with door closed: Link
Link
Side window:
Link
Link
Side off:
Link
Link
Link
"Let me know what sucks and i'll work on it!"
What sucks is your links not working. Try doing a reply (quoting) to a post with links and you will see the code. It's simple enough. The easiest way to create a link is to click the "http" thingo in the blue bar on top of the editing window as you compose your post. Of course, you can cancel your send if you don't really want to post. As you can see, I've fixed all your links by doing a replace of each with [<the letter L>=Link] and each with [/<the letter L>].
Ach! Well, it appears that your URL's aren't working. For instance, http://images.dr3vil.com/uploads/IMG_9524[1].jpg
vwtankgirl
62
http://www.mini-itx.com/
I like the Mini-ITX platform and what some folks have done with it.
One of my faves is the XP box... they used a WinXP box to build the system in. I also like the aircraft carrier and the old C-64 updates.
