Muse
Originally posted by: presidentender
Originally posted by: gramboh
If you are going to do lat pulldowns, make sure you warm up well on them. I tweaked my shoulder a few times doing them last year (I never do them anymore). I'm not sure if I had bad technique (likely) or I just tried too heavy weight without warming up, but it did not feel good. I was pulling the weight to my chest while leaning back a bit.
I was in love with a wider grip for a long time, because it made the exercise harder. However, you can bork your shoulder pretty badly, especially if you go "all the way" down with the bar with a very wide grip on heavy weight. Wide grip is okay, pulling the bar down past your chin is advisable, and heavy weight is great. Just not all at the same time, please.
Years ago I stopped doing pullups on a single horizontal bar, instead using parallel hand-holds. It's a lot easier on the joints. Take care of your joints!
