Can my PSU handle 2900XT Crossfire? **UPDATED**
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Originally posted by: apoppin
no it fits in a drive bay
http://www.ewiz.com/detail.php?p=PS-EP4...9b5702824ef2ba45e28039e085e46333e1c1c5
* 5.25" hard drive bay size power booster
* Extra 450W power on top of current power supply
* 3x high speed fans optimize thermal release
* Support EPS 12V 8pin and 4pin Upto 38A
* Support PCI-E 8pin and 6pin
* Modular cable design
# Total Power: 450 W
# Application: Additional power
# AC Input: 100 ~ 240V, 50 ~ 60Hz
# DC Output: +12V1&+12V2 @ 20A
# Max Output Current: 38 A
# Cables: 1x 4pin EPS 12V; 1x 8pin EPS 12V; 2x 8pin PCI Express for Quad SLI and CrossFire Video Cards; 2x 6pin PCI Express for SLI or CrossFire Video Cards; 1x Connect to wall jack and cable tide
# Color: Black
# Dimension (WxLxH): 145 x 185 x 42 mm
# Weight: 4 lbs
not cheap ... $90 ... but doable [this was posted in the 'connector' thread]
and check here to make sure you have no prob with connectors or PS:
http://ati.amd.com/technology/crossfire/buildyourown2.html
my 850w OCZ isn't on it :(
... it isn't even recommended for x1950 xfire ... but it is probably an 'oversight' as it's littl bro is
the OCZ 1010* watter is :p
[ * 2x4 Power connector functionality is achieved via an included adapter cable.]
Huh, interesting, I have never heard of that. After all is said and done though, after selling my Seasonic, it will probably work out to not too much of a price difference when compared to just buying one of the big daddy PSUs. :p
Time to check and see if they sell those add-ons up her in the Great White North! :D If the prices are decent it may be the way to go.
KT
apoppin
34,890
alienbabeltech.com
# Color: Black
# Weight: 4 lbs
KT
well, definitely pick one off the list ...
higher wattage is better
:D
and i emailed eryder of OCZ - who appears on these forums also - to ask about a 8-pin adapter for my OCZ ... so i'll post his reply
i am NOT upgrading my PS for xfire ... :|
... not when i can run GTX sli :p
so ... lot depends on 'what happens' as to XT power issues ... as to which multiple GPU-capable MB i will pick
KeithTalent
Administrator
Nov 30, 2005
50,231
118
# Color: Black
# Weight: 4 lbs
KT
:D
Good stuff. Definitely post what he says. :thumbsup:
I just looked around at some Canadian shops and this is the only booster I can find:
http://www.ncix.com/products/index.php?...300-1E01&manufacture=FSP%20GROUP%20USA
Which I do not think will cut it. :(
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Originally posted by: JeffreyLebowski
If you get the TT 1200 make sure it will fit in your case.
Hmm, looks nice. $400 is kind of steep(Linkage to TT 1200), which is why I am sort of leaning towards the last two I linked to, over the TT.
Is this thing longer than regular PSUs? :confused:
Thanks,
KT
lamere
479
Originally posted by: myocardia
This one shouldn't have any problems running Xfire'd X2900XT's: PC Power & Cooling Silencer 750. Of course, any of these will work, if that one's too cheap for you: 1,000 watt Silverstone, TT Toughpower, and PC Power & Cooling.
i dont know about that PC&C 750 - i'm not saying it wont work, but i have one running 2 X1900XT's and the moment i bring up stalker or cellfactor, oblivion or anything fairly recent game, that PSU gets to cranking, like its getting pushed.
it does seem to handle the load just fine, but makes me wonder how much MORE it will take.
And the 'silencer' 750, not so silent, for peeps looking for a quieter PSU.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Ok, this is it, I have put the TT 1000W into my cart and am about to pull the trigger, unless someone can convince me otherwise! :D
I have also found it for $15 cheaper than before, so that's nice: http://www.directcanada.com/products/?s...34&vpn=W0132RU&manufacture=THERMALTAKE. :cool:
The 1000W one is enough right? I do not want to have to upgrade my PSU for a couple of years now if I can avoid it.
4, 3, 2......
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
weight!!
.... broke the bridge :p
how much is $345.60 in real money?
:D
Oh, it's 2,444.60 in Chinese Yuan, sorry about that. ;)
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
i meant Euros
:roll:
EU-237.81
OMG the US dollar doesn't buy much [anymore] ... is it US $320?
:Q
Yep, pretty soon us Canucks are going to head South and start buying all of your land. ;)
We're getting $0.92 on the dollar today...the end is near! :p
KT
apoppin
34,890
alienbabeltech.com
as long as you guys don't buy up NewEgg, i am OK with that
and NewEgg charges the same as your outlet for the TT
http://www.newegg.com/Product/ProductLi...8+50001379+1131428171&name=Thermaltake
$329
go for it!
[are you *sure* you don't want the 1200w TT?]
:Q
Ultra-high efficiency up to 87%+, PCI-E: 3x6 PIN & 3x8 PIN
Thermaltake Toughpower W0133RU ATX12V / EPS12V 1200W Power Supply - Retail $389
and there are now adapters
http://www.performance-pcs.com/catalog/...in_page=product_info&products_id=21721
Product Details:
*** NEW Custom made Male 6-pin PCI Express to Female 8-pin PCI Express 2 adapter cable from Performance-PCs.com ***
This adapter can be used to convert any 6-pin power supply PCI Express cable to a 8-pin PCI Express 2 cable. This adapter is handy for any modern PSU you recently purchased that needs the 8-pin PCI Express 2 cable connection such as for the new Radeon HD 2900 XT.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
$329
go for it!
:Q
Well if I was in charge, Newegg is what we would take first! :D
No, I am definitely not sure I don't want the 1200W TT. For $35 more, is it worth it or even necessary? :confused:
KT
Edit: Just saw your edit. Now I think I am confused by how many 8-pin PCI-E cables I need. I was under the impression it was only 2 and I was also under the impression the TT 1000W had 2. :confused:
KeithTalent
Administrator
Nov 30, 2005
50,231
118
that is WHY i posted it
you *need* to be sure
... i though $180 was a little 'steep' for my OCZ
:confused:
i think mine would be very "marginal" for HD2900xt xfire ... adapter or no adapters
Arrggh. Well I just sent an ETA request to my E-tailer of chjoice to see when the 1200W TT will be arriving. I can buy it elsewhere immediately for $20 more, but it is not like I need it today or anything (though of course I want it today). :)
Thanks Poppin!
KT
apoppin
34,890
alienbabeltech.com
:confused:
Thanks Poppin!
KT
another "edit"
... all three TT PSes are on AMD's xfire list from the 850w thru the 1000w to the 1200w
Toughpower Cable Management 1000A (W0132) (1000W)
you should be OK
should be
it appears the 1000w and 1200w share the same number of connectors ...
but ... IF you are going to spend that much ... it looks like the 1200w will be much more "future proof" ... especially if you are gonna go for Quad-Xfire
:Q
KeithTalent
Administrator
Nov 30, 2005
50,231
118
:confused:
Thanks Poppin!
KT
another "edit"
... all three TT PSes are on AMD's xfire list from the 750w thru the 1000w to the 1200w
you should be OK
should be
Hmm, well for the extra $35 I may as well go ahead and get the 1200W. I guess no Starbucks for me for the rest of the week to make up the difference! :(
Thanks again,
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
:Q
Lol, Quad-Xfire...I can only imagine the noise, heat, and power from that... :shocked:
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
perfect for your Winter!
think positively ... even if Winters are getting warmer :p
you will have a Beast of a rig with HD2900xt Xfire!
--nice!
Right, going to go for it, once the e-tailer gets back to me.
I may need to move my pet rabbit out of the computer room though, I don't want to end up with fricassee! :Q
KT
KeithTalent
Administrator
Nov 30, 2005
50,231
118
OK, just to update, I bit the bullet and ordered the 1200W TT. I found it for $10 cheaper somewhere else, so all in it came to ~$400 (well $398.67 to be exact) which is quite a bit for a PSU, but it should get me through for a few years at least. :D
Now, I just need to wait a little while longer until the 2900XTs drop in price a little...
Thanks for all of the help everyone!
Cheers,
KT
apoppin
34,890
alienbabeltech.com
Cheers,
KT
OMG that's $367 in real money :p
:Q
--maybe you can split the TT's output to run two or three [or 4] rigs while you wait for your HDs
:D
and it appears this is the "math" to OC xfired HD2900xts
PCIe slot =75w
1x 6pin PCIE = 75W
1x 8pin PCIE = 150W [which can't just be a 6pin to 8 pin adapter or it would still be 75w]
... so 300w to OC it .. 225w for just the 75w slot, the 2 x 6pin PCIE 150w
600w for 2 oc'd HD2900xts
:shocked:
i think your new PS is OK ...
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Cheers,
KT
:Q
:D
PCIe slot =75w
1x 6pin PCIE = 75W
:shocked:
Well I was hoping to mod my beer fridge to run it off this thing as well. I'll let you know how it goes! :D
600W!! Yowzer! This thing had better be more than just OK for $400. :p I'm hoping to have extra juice for some overclocking too...
KT
