Hello all
I need a PC for CAD modeling ( Autodesk Fusion 360, Solidworks ) and 3D rendering (Keyshot). I've made some research and I think I know, more or less, what I need but since it's going to be my first build I would like to hear your opinions, suggestions and overall input.
1. CPU: Ryzen 2700X
I know that CAD software prefers faster cores, instead of more cores/threads so Intel CPU's might seem like a better option but in my case rendering is a priority.
2. CPU COOLING: be quiet! Dark Rock Pro 4 – Will it be sufficient to keep 2700X really cool? Anybody have any experience with this cooler and 8 core ryzen chips?
3. MOBO: Here comes my biggest concern...
I'm gonna use my rendering software for long hours, which means that CPU will work under 100% load on all cores. This is why I would like my motherboard to have decent VRM (to keep things cool and stable) and also be futureproof for the next generation of Zen CPU's.
For years I've been using Asus motherboards and never had any problems with them, so my first pick was Asus Prime X470-PRO. As far as I can tell, it has decent VRM design and is quite affordable. But after I watched buildzoid's test of this board, which included thermal testing, I'm a little bit worried if it can handle the heat during long and heavy workload?
I also considered Asus X470 Strix-F (similar VRM, larger heatsinks) but thermal images that I've found over the internet, show that in harsh conditions it can run pretty hot too. Looking at the pictures in the link below Asrock X470 Taichi seems like the one to go with. But is it really worth stretching my budget? Or maybe I'm already overthinking? Btw. I'm not going to overclock my CPU for now but I would like to make the best use of Ryzen optimalization, auto-boost technologies.
https://imgur.com/r/Amd/yZsgmPq
4. RAM: G.Skill 16GB 3200MHz Flare X Black Ryzen CL14 (2x8GB) F4-3200C14D-16GFX
5. GPU: Msi Gtx 1060 ARMOR 6G OCV1 ( from previous PC )
6. SSD: Crucial MX500 500GB SATA
7. STORAGE: 2 X Seagate 500GB HDD ( from previous PC )
8. PSU: Tagan 600W TG600-U33II ( from previous PC )
9. DISPLAY: EIZO EV2736W 1440p ( from previous PC )
10. CASE: Here I can't decide between Fractal Design Define C and Meshify C. I would prefer the first one since I would like this build to be as quiet as possible (working at home) but the second one will probably have better airflow. In both cases I'm going to add two - be quiet! Silent Wings 3 140mm PWM fans. What kind of temps can I expect? Is Meshify C tolerable in terms of noise levels under full load?
I'm gonna appreciate any tips, suggestions and things to be aware of...
1. CPU: Ryzen 2700X
