This 4 cylinder has a Timing ChainTIMING BELT replacement interval for the new CIVIC
A motorcycle chain and a timing chain are entirely different beasts. Most timing chains are fully enclosed and not exposed to various loading like a motorcycle chain which has to change position slightly depending on the location of the rear wheel.Gee! That seems counterintuitive! All the "old" American cars, like my old 64 SS Impala, had timing-chains. So I assumed that Japanese cars simply continued the practice of using timing belts at least after and as early as I discovered use of a timing belt on my 79 CIVIC.
Of course, chains can break. I had a college friend with an old 500CC Indian motorcycle. His chain broke -- when I was riding it out among the foothills and orange groves around Riverside. A real pain in the ass. No cell-phones then -- it was 1966. Some guy in a truck happened to come along.
But I wouldn't hold my breath for a timing chain. The belt on my Trooper has a 60,000-mile expected lifespan; after that, I'm at risk if I don't have it replaced.
A timing chain should last longer than a motor in nearly all circumstances. Timing belts stretch, wear out, and can be affected even more greatly by idler pulleys and accessory pulleys. I've seen plenty of timing belts get shredded due to a shitty idler pulley freezing up which in turn ruins your top end if you have an interference engine.
Timing belt on my first car made it to around 100k before I replaced it. I got the car around 90k IIRC. It probably would have gone longer than that but I did a major overhaul at that point - replacing the oil & water pumps, the valve stem seals, all the belts, and all the oil seals I could access.
Chains have all sort of problems too. I don't prefer one to the other per se but it does seem that belts are better just because they're designed to be replaced. I'd rather (easily) replace something as preventative maintenance than have to deal with a PITA item that wasn't designed to be replaced. Nothing lasts forever.
Generally a bad catalytic converter shouldn't affect the O2 sensor and your rich/lean mixture. You probably have an O2 sensor before the catalytic converter that is used as input to the ECU when you're not operating in open loop mode. FYI generally most cars when "Cruising" operate off standard fuel maps rather than the O2 sensor readings.When I bought my 95 Trooper in 2002 with 96,000 miles, there were a whole bunch of things I didn't anticipate. Retirement was like getting out of school for the summer: it comes with an "attitude". I think my water-pump froze up in 2009; the car overheated; the radiator was damaged. Since the pump is driven by the timing belt, the timing belt broke. Towed to the mechanic, he warned me I might have damaged valves, blown head-gasket, etc. We repaired it. No damage to the engine or head-gasket. New belts, radiator, timing belt, thermostat, etc. I think I'd put 62,500 miles on the car myself, and I'm quite sure the previous owner hadn't replaced the timing belt just before he sold it. The replacement interval is 60,000 miles.
Continuing from my answer to deadlyapp, I now track all this stuff. Luckily I'd been scanning all my shop orders into my document database since I bought the car, so it took me maybe a day or so to get the data into a spreadsheet. I think I have about 29,000 miles remaining before the belt is changed out. It's about a $500 expense. Could be a bit more now. But that has to be about 5 years away, given the annual mileage habits. Probably longer.
Well, the thread topic is smog standards and changes. This dovetails with another current thread about a Repair Shop of Horrors. I'm trying to get the gas mileage back up to spec, and making progress. I cleaned the MAP sensor -- they don't go bad, but they can get dirty. I believe that cleaning the contacts to the three wires -- one a variable signal wire -- probably gives the ECU better data. "AFTER" was better than "BEFORE" -- making sure the ECU was reset before firing it up. I think we'll make it back to the "city" spec of 14 mpg. Most of my driving at the moment is definitely "city". For that matter -- ALL of my driving at the moment.
There are absolutely no symptoms now that would suggest a bad HO2 or IAT sensor. I'll ask the mechanic. Those are really chump-change parts. I'm going on the assumption that a sensor can age and get out of calibration in such ways that it wouldn't trip the "Check engine" light, but only warp the ECU's ability to change fuel mixture on the fly. Another tank of gas, and hopes that it will show something above 13 mpg.
I'm also thinking to clean or replace the EGR valve. My smog-test NOx have gone up over the years, but only to about 40% of the MAX standard -- hovering there for the last four tests. Cleaning with success would save $135 in outright EGR-valve replacement. After that, perhaps a new catalytic converter? My new mechanic isn't too enthusiastic for these thoughts -- which is good. He wants to save me money . . .
Still debating whether to post a bad review for the Shop of Horrors on Yelp. A sense of resentment lingers . . .
No doubt you know about these things, and I am in a newly-rejuvenated learning mode. I'm kicking myself because I never fretted about any of this stuff a decade ago when I already had the factory shop manual in my possession.Generally a bad catalytic converter shouldn't affect the O2 sensor and your rich/lean mixture. You probably have an O2 sensor before the catalytic converter that is used as input to the ECU when you're not operating in open loop mode. FYI generally most cars when "Cruising" operate off standard fuel maps rather than the O2 sensor readings.
Honestly I think you're too worried about your MPG. If you want to make a big impact to it, go buy yourself a tuning box (if there's even one available) and lean out your fuel mixture, which is generally conservative from the factory. Your car is old, fuel efficiency decreases with age as piston rings wear, sludge builds up, etc. At some point you get significantly diminishing returns (is another $5-10 a week worth spending several hundred dollars and perhaps getting no real change?)
When I asked my smog-test guy what might be a good replacement for my Trooper, he was quick to suggest the 4Runner, although I assume he meant one of more recent production than your son's. Even so, the Toyota line has a marvelous reputation for longevity. My Moms' old '83 Corolla was still road-worthy and a helluva peppy ride until 2016, when we couldn't find a new emissions-control device that would otherwise have cost a mere $134. They just don't make those items anymore, and a junkyard part with a rubber diaphragm would not be a good bet -- even if we were able to find one (and we weren't, anyway). So we took the cash-for-clunkers check -- a good deal for a 33-year-old Corolla with 220,000 miles on the odometer.My son drives a 1998 Toyota 4Runner with 215k miles on it. We bought it a couple years ago and had to smog it because you have to do this when transferring between private parties. Anyway, it passed with no trouble. It has the original exhaust on it and it is completely stock. I have no idea what the numbers were nor do I care. It was purchased new in this state though so it is CA compliant, as are nearly all new cars these days. It gets pretty abysmal mileage of around 15mpg but he only drives to school and to his friend’s houses nearby so it doesn’t matter too much.
Any car 1975 or older is exempt from CA smog testing requirements. I believe the thinking is that vehicles this old and older represent a very small percentage of vehicles and a very low number of miles driven annually so there is little benefit in testing them. The 63 El Dorado and the 75 Blazer would fall into that category.
(300 + 60) X [approx.] $500 = $2,500All of the timing chain failures I've heard about in modern engines were caused by failure of the tensioner (generally easily replaceable part, at least in my Civic 1.5T), failure to change oil on time (Those photos of the horrifying 30k oil change interval idiots are doing these days), or running the oil level low for extended periods.
If a timing chain is maintained and has no manufacturing defect, it should easily last 300k+ miles before it will have stretched enough to cause a problem. How much will you have spent on timing belts in that amount of time?
Just the luck of the draw -- so many cars had timing belts since my '79 Hondas, I couldn't enumerate. So . . . now they've decided to use chains again?
Even so, problem with the newer cars -- I've heard that it's even near impossible to get to the spark plugs to change 'em yourself . . .
I had my tensioner replaced a while ago . . . lemmeseehere-aminute . . . OK . . . 22,000 miles ago . . .
UPDATE: Let me correct my opening estimate response. At $375 for timing-belt replacement, that would cumulatively be $1,875 over 300,000 miles. I'll probably be dead before another 100,000. Frankly, I'll only put 3,000 miles on the car per year, so 15,000 miles is five years from now . . .
With the limited information I have about the latest models over the last ten years, that was just something I heard -- that they were making it hard to access plugs. So if I'm corrected, some are "this way" -- some "that way" -- or they can vary and be different?. . . . . . . .
. . . . . . . Also practically every transverse mounted 4 cylinder has stupid easy sparkplugs. Generalizing something as complex as automotive design doesn't benefit anyone.
