Buying dip belt
paulxcook
4,277
I believe chalk is just chalk wherever you get it. As for the belt... *shrug* That's why I made my thread about lifting belts.
glenn beck
2,380
I usually prefer the non-leather dip belts, leather ones rub into my side with the heavy weight
MegaVovaN
4,131
So you would get something like this?
@paul: I don't have any chalk...
glenn beck
2,380
yup, the leather ones are more prone to dig into your sides, because they are
a denser material
paulxcook
4,277
I know, I was just saying that wherever you buy it, as long as it's chalk for lifting it should be fine. I don't think one chalk is all that much better than another.
DAPUNISHER
31,129
29,466
I ended up buying APT CRT linked for me months back. Found it through Amazon for $35 shipped at the time. Best $ I've spent on anything exercise related in a long time. You will definitely dig it.
MegaVovaN
4,131
Thanks for the link Punisher, but I already bought the fabric/nylon belt right above your post.
RagingBITCH
17,618
You know I could have sworn I recommended getting a dip belt, and you said you didn't need it for the weight you were using it for :p
http://www.bodybuilding.com/store/griz/grizfbelt.html
That's the belt I have...I've loaded 70lbs on it without any discomfort...it's a solid belt. Depending on your waist size, you'll probably wrap the chain twice before putting weight on there. (It'll make sense once you put weight on there)
MegaVovaN
4,131
Well you're right, you did :)
Now I do need a belt, Monday I'll be doing 20 lb and that cuts me already. Waist is about 37-40. Don't know how to measure it.
BTW, Monday night I will go to DJ Tiesto clubbing...so much for sleep and recovery from lifting and summer class Tuesday :) Or is it an "active recovery" with 4 hours of dance/jumping?
but hey - it is an once-a-year event!
imported_Irse
269
Do you already have a lifting belt? We used to use our own belt and have a chain with clamps on both ends. One end clamps onto the bucket, form a loop to put the weight on and clamp it back onto the chain. It cut down on the rubbing since the belt would be a tight fit anyways. Since we already had the belt, it didn't cost much.
MegaVovaN
4,131
Nope, I don't have a lifting belt already - it will be a long time before I need one, my current lifts are laughable (5 rep work weight in lb: squat 150, dl 180, Press 95, bench 140).
RagingBITCH
17,618
That's not laughable...we all start somewhere my friend. Just keep at it. :thumbsup:
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
my CK belt does okay with me :p j/k
Dip belts are fine, now you can smash out weighted chins and pull ups also :D
Koing
TallBill
46,017
62
Koing
Yeah, I was doing bw+70 lbs dips for a while. Now my shoulder is fuxored from something else.
Never used a regular belt though.
MegaVovaN
4,131
I though I typed a reply but it vanished?
Anyway, my hole of a gym does not even have anything to do dips on. So I bought belt for chins/pullups.
dealmaster00
1,620
Just wanted to say I just ordered the same one you did MegaVovaN. Not sure how much longer my backpack is gonna hold out with the extra weight in it. :D
purbeast0
53,453
6,300
i actually want to grab one of these belts too. holding a 30lb dumbell w/my feet for pullups is just becoming too difficult.
