Modelworks
Cheap and UPS usually aren't good ideas.
I had this exact one installed last month. I hope it does what its suppose to.Originally posted by: Modelworks
Another option rather than plugging everything into surge protectors all over the house is just to get a whole house surge suppressor installed. They cost about $120 + installation and cover everything in the home.
http://www.homedepot.com/webap...eed-_-D27X-_-100396483
That's a 'light-medium duty' surge suppressor using MOVs to divert the surge, capable of dissipating normal spikes due to operation of heavy motors (e.g. AC) and distant lighting strikes. Like all MOV suppressors, it will wear out with use and may operate in a sacrifical mode during a maximal surge.Originally posted by: FlashG
Originally posted by: nonameo
So, did we ever get an update on the whistleblower thing?
Originally posted by: zinfamous
question:
i'm moving into a place with un-grounded sockets. (currently lobbying to get them grounded via landlord or pops--i'm no electrician)
is it completely stupid to simply plug a UPS/COnditioner/Surge protector--whatever--into an adapter for a simple 2-prong outlet? What perils would I face by going this route?
oh, I should mention that my plasma, + receiver + ps3, etc...and computer stuff will be plugged into these sockets.
did you have someone install it for you, or did you do it yourself? I'm not real comfortable doing electric work. what is involved in putting this in?
Originally posted by: AccruedExpenditure
How often do destructive power spikes happen? I haven't experienced one in the US before. Are they common occurances?
As long as they aren't used heavily, as in the battery backup part of the system, the batteries could last 8-10 years, and should last at least 5.Originally posted by: Freejack2
I don't think I've ever had destructive power spikes here but I did lose a power supply once when we had a power dip and the battery in the UPS was dying.
Replaced that with a APC BackUPS Pro 1100 that has buck and boost, haven't had a problem since.
Though now that I think about it the UPS just turned 3 years old. Anyone know how often the batteries need to be replaced on these beasts?
question:
Not a good idea. The surge protector will use the ground to divert the surge. Without it, you're boned.
Originally posted by: biggestmuff
AN
Originally posted by: chusteczka
The OPTI-UPS and the Powercom are not UL certified. Is this important? I have used the OPTI-UPS for a year now with no problems and have been purchasing these as gifts for friends and family.
Not unless you don't care about the posibility of a fire.Originally posted by: chusteczka
Products with Automatic Voltage Regulation (AVR)
Line Conditioners:
- APC LE600 6.5 feet 4 Outlets 680 Joules Line-R 600VA Automatic Voltage Regulator for $56.
- APC LE1200 4 Outlets Automatic Voltage Regulator for $66.
- OPTI-UPS SS1200BLK 6 Outlets Voltage Stabilizer for $35.
- powercom TCA-2000N 6 Outlets Voltage Regulator for $30.
