Amused
- Apr 14, 2001
- 57,347
- 19,512
- 146
Originally posted by: CocaCola5
When was the last global warming period, I thought the earth was either in normal or in ICE AGE, not warming...
What is "normal?"
Originally posted by: HappyPuppy
For the third time I am challenging the environmentalists here to explain to me how the hydrocarbons emmited from our automobiles caused the Earths environment to go from Ice Age to what it is now. Did Barney Rubble drive a Chevy Surban that emitted pollutants that caused massive changes in the Earth's environment?
Although the exact causes for ice ages, and the glacial cycles within them, have not been proven, they are most likely the result of a complicated dynamic interaction between such things as solar output, distance of the Earth from the sun, position and height of the continents, ocean circulation, and the composition of the atmosphere.Next time, do your own research. I am educated on the matter, you naysayers are not. Please educate yourselves.
Normal is like the opposite end of the temperature ranges from that of Ice Age, its where the climate has been for about the last 20,000 years.Originally posted by: AmusedOne
What is "normal?"
IOW, this is ALL speculation and theory, not fact. Moreover, its speculation and theory which is based on further layers of speculation and theory. Wow, that's compelling stuff!
Hopefully the dumb@$$'$ that keep saying we do nothing that harms the planet will learn
Why do you whine about things that you know nothing about?
Pre-industrial levels of carbon dioxide (prior to the start of the Industrial Revolution) were about 280 parts per million by volume (ppmv), and current levels are about 370 ppmv. According to the IPCC "business as usual" scenario of carbon dioxide increase (IS92a) in the 21st century, we would expect to see a doubling of carbon dioxide over pre-industrial levels around the year 2065.
Global surface temperatures have increased about 0.6°C (plus or minus 0.2°C) since the late-19th century, and about one half degree F (0.2 to 0.3°C) over the past 25 years
What is "normal?"
Please. Global warming and cooling are caused by cyclic changes in the orbit and tilt of the planet Earth as well as the changes in temperature radiated from the Sun. Hydrocarbon emissions emmited from internal combustion engines do not have any effect on the the temperature or climate of planet Earth.
It has changed but for the most part it has kept constant, I believe.Has the climate been a constant for the past 20,000 years?
Ah yes, the ideologically charged Intergovernmental Panel on Climate Change (IPCC) who was caught doctoring its reports and failing to include among its findings the comments of dissenting members of its panels and working groups, and when confronted with gaping flaws in its conclusions or methodologies, has been forced to REVISE its predictions for the rate of global climate change now three times. Hint: it didn't raise the predicted rate, it lowered the predicted rate each time.According to the IPCC "business as usual" scenario of carbon dioxide increase (IS92a) in the 21st century, we would expect to see a doubling of carbon dioxide over pre-industrial levels around the year 2065.
OMFG! The earth is going to explode....RUUUNNNNNNNNN!In general, the report does not expect extreme disasters, such as a huge rise in sea levels. It projects an increase in global sea levels ranging from as little as three inches to as much as three feet from 1990 to 2100.
It lists the "very likely" changes during the 21st century as:
? Higher daily maximum temperatures and more hot days over nearly all of the Earth's land.
? Warmer overnight low temperatures.
? Fewer cold days and frost days over nearly all land.
? Reduced differences between daily highs and lows over nearly all land.
? More intense rain or snow storms over many areas.
? A higher risk of summer droughts over inland areas of the middle-latitude continents.
The panel also thinks that hurricanes, typhoons, and Indian Ocean and South Pacific cyclones are likely to produce higher winds and heavier rain in some areas, but there's no way to tell whether the frequency and locations of these storms could change.
The report notes that no global changes have been noted during the 20th century in terms of the numbers of storms or their strength. "No systematic changes in the frequency of tornadoes, thunder days, or hail events are evident in the limited areas analyzed," the report says.
While snow cover and sea ice in the Northern Hemisphere are expected to continue decreasing, and glaciers should continue retreating, (as they have during the 20th century) the Antarctic ice sheet should grow. This is expected to happen because warmer air can hold more humidity, which will increase the amount of snow in Antarctica. This in turn, will offset some of the water being added by melting glaciers and some melting of the Greenland ice cap.
Ho Hum. Another frantic tree hugger.
How so? I think its dumb to not think forward. You have to. It's just like a business. Don't think forward, you fail. We as a human race will fail if we neglect to take our actions into account. Maybe we cause global warming, maybe we don't. Either way, its worth it to reduce our impact on the environment. If that makes someone a "tree hugger", then you're just plain ignorant.
my some of you people are really really dumb, i'm sorry but please, i'd like my childrens children to live on the planet without having to have some kind of oxygen mask things, etc. I wish we could boot you dumb people who think everything we do has little to no impact on earth to mars and you all live there and do whatever the hell you want
I agree, but for slightly different reasons. We make a WHOLE LOT of other valuable 'stuff' out of oil besides fuel to power internal combustion engines, and the earth's oil reserves belong to future generations every bit as much as they do to us.the main reason we should stop using all those fossil fuels and pollutin' is incase we run out, we may have 50 years, 200 years worth of oil below us, but remember china and other 3rd world nations become industrialized they'll guzzle it up as bad as we and then their will be no more and we're skrewd
Originally posted by: XFreebie
exactly, these plants love this CO2 stuff, they just eat it right up
IGBT: you are a troll. Science is the source, the environmental movement is the taskmaster. Shut up.
