Burn in week (my method)
Originally posted by: BarboBot
lmao this is bad vegitto but one more question (the program works friggin great btw) how do i post the pix i've got the ones you wanna see (well below 1.2v)
use imageshack or bbzzdd to host them. free sites then you just post the linkage.
mine's running at 1.05volts right now. that's what cool & quiet is for. 😉
Well, Budman, the 'burn-in' descripted in that guide is different from this method. The method you posted allows higher voltages to be ran in the processor on stock speed (for example, 1.8 GHz not at 1.3V but at 1.5V). The method BarboBot uses allows only lower voltages (for example, 1.8 GHz not at 1.3V but at >1.1V).
i'm not a big fan of cool n quiet seeing as to how i couldn't lower the voltages any lower then 1.375 with it on and i've heard its not good for overclocking in its present state
well, cool n quiet with rmclock is a better solution than the regular method. at least from what i've seen. my idles cool to 1.1v. anyway, thats not what this is about. i'm interested to see the reults and i'll try getting back to mine next week probably
and thanks for the linkage vegitto, i was tired.
its so you can overclock higher at lower or stock voltage. you're training you parts to run with stability at lower voltages, the lower the voltage you can run at stabily the less power consumption, also less heat is generated, i'm running an air cooled system and i'm into the second phase of this experiment and its already running cooler. (at stock volts 1.4 the cpu was running at 37-39c now its halfway through the 1.36 volt burn in session and its only 35-36c) so its running cooler also after this week is up i'm planning on running the test again at stock voltage the end result i'm looking for is higher over clock at stock voltage and lower temperatures under load. (ohh and on side note prior to this burn in my comp ran at 32c i checked it today and its down to 29c at idle) I've read many a articles about cpu burn in and there is sound proof of it working should you look into it. www.ocforums.com has a lot of info/guides on the topic. granted my method of burning in is slightly differs from the conventional method used i'm just trying it out to see what results i get (so far the results in my two days of this experimental burn in has yeilded positive results)
FALSE
components DEGRADE over time....not improve...your cpu is not a "dog" you can teach tricks to...burning in, besides (as mentioned already) really only helps CERTAIN types of memory (BH5 especially)...
"old wives tale"
Originally posted by: theman
me want teh pics!
Me too.
And you all can say that it doesn't work, but if you have seen Sentential's results using this method, you'll know better 😛.
omg all you have to do is read the threads that i've posted i'm not saying it 100% does work, but i find it highly unprobable that that many people can be equally decieved by that method (most of which are far more or as knowledgeable as the 70% of the people in this forum)
ohhh and here is some even better proof for ya (yeah you got it screenies!)
http://pics.apartment808.com/users/Barbobot/Snap1.gif - 1.2v CPU-Z, 1.36 Asus Probe with temp read out there for ya. and by the way that article you guys are priding yourselves with as the be all end all to cpu burn in being a myth is talking about running your cpu at higher than stock voltages which isn't what cpu burn in is about at all and further more i've never heard of anyone doing that and basically it seem pretty moronic in nature for someone to do that anyway seeing as to how it will fry your cpu and definitely take away from the life and the efficiency of your cpu and components. but anyways here ya go 🙂
What's wrong with a lower vcore? I would think that it would be a good thing, since going over the stock vcore takes years off your CPU's lifespan. And if he can get a stable boot, why not.
Btw, Barbobot...that 3200+ Venice has a lot of OC potential. Put it back up to stock vcore, and you should be able to get to 2.4ghz easily.
Well after reading a lot of info on cpu burn in i've decided to burn mine in due to the increased performance on lower power. i went through and found the stock voltage for my 3200+ venice was running at 1.4v so i ran cpu burn in for 12 hours at the stock voltage (no problems) next i've moved it down to 1.36v i'm running another 12 hour burn in session then i'll move it down to 1.2v then another 12 hour session. I'm hoping to get increased stability with this gradual burn in process as opposed to trying to go straight to the lowest voltage possible. I'm also hoping i can get a little bit lower voltage than the traditional burn in process since i'll be gradually building up stability at lower voltages. I was just wondering if anyone else had any input or suggestions/opinion on this process?
fool. why don't you just drop it all the way down at once to see if it worked. then we would know if there was a difference or not.
cause this method is allowing me to go lower more stabily and i'm aiming for stability so i'm trying to get the most results from a stock voltage or less this process is aimed at letting me get a stable burn in at less than 1v from the results i'm getting thus far. but what you're trying to critize me about is the general method for burning in a cpu (i'm choosing not to do that and this is a test for my approach to the burn in which is slightly different so thats why i'm not going straight to the lowest voltage possible and honestly i don't think it would be as low of a voltage as what i will get with this method but we'll see this is a test)
How about you aim for >1V, and then overclock until you're back stable at stock voltage (or slightly under it)?
Sorry for not posting sooner the test is over and the results are in (I hit rock bottom for the test at 1.10v no matter what i set it at the cpu wouldn't run on anything less than 1.10v, it would be set in bios to .05v it would be running at 1.10v so with that said here they are).
Stability - There was a noticable increase in stability once the cpu was set back to stock voltage (1.4v). mainly in the smoothness of running applications and running multiple applications (which is partly why i got a 64bit proc on this gaming build TS running with game running and possibly windows media player)
Temp changes - here is were the noticable change was the cpu was idling at 37c-39c under load now its running at a solid 33c under load it was idling around 35c now its idling at 30c or lower. Case temp had also dropped with the falling cpu temps which was expected.
Conclusion - I'm gonna have to say that with the results shown here there was a drop
in temps and running stability that are too defined to pass up or write off. In this case with this method i'm gonna have to say this experiment was a total sucess. I'll will be going through and pulling out the data to make a definitive guide for this burn in method. I would like to thank everyone who gave input (good and bad 🙂 ) it offered me motivation to go through with this. I will be starting another thread once i get my setting right for an over clock and possibly a memory burn in experiment along these lines to see what results i can get :beer:
Was there any change in the stock temps/stability before and after the voltage lowering session? Or was the difference only between 1.1v and 1.4v?
I'm not going to argue with temp changes, but I question how "stability" can be better - how the system can be "smoother" after burn-in - at the same speed as before. I'm convinced that there's something else at work there, and unless you can prove it with benchmarks, I'm also convinced that it's mostly or entirely psychological. The temperature change, whatever the cause, does however look convincing.
