While technically you were correct in that an electron won't "shrink", it had everything to do with luck and nothing to do with actually understanding what was going on. If you realized that they don't really have dimensions, it's not like you would have brought up size in regards to an electron to begin with.
You're basing your entire view on some sort of model of electricity that you've made up in your mind.
I only skimmed the thread before replying, so I'm not really sure what your point is, but I felt the need to clarify a bit. Electrons are an elementary particle. We can't really discuss them like they're tiny little negative bb's and actually mean much of anything.
what is your model of electricity?
mine is water model.
http://www.google.com/search?client=safari&rls=en&q=water+model+of+electricity&ie=UTF-8&oe=UTF-8
I did not make it up.
transistor size would be pipe size. small pipes result in more restriction of electric flow. there is more stress on a smaller pipe.
I am not saying that ivb cpus will fall over dead in a year.
I am saying why risk using ivb for small cpu gains when you are over clocking. you only need wait to see if they are any good.
When ssd's came out they were an amazing improvement over hdds in iops. so the speed gain is worth the risk if you do a lot of iop based work.
the ivb is not 10 or 20 x gain over Sandy b. so waiting to see if they last is not a bad idea.
If you go out today you can buy this mobo
http://www.newegg.com/Product/Produc...82E16813131806 for 170 with the discount
http://www.newegg.com/Product/Produc...82E16819115072 buy this cpu for 204 = 374 total.
It is a known factor that oc this to 4.2 and a year later it will still work.
or buy this for 240-10 =230
http://www.newegg.com/Product/Produc...Tpk=i5%203570k
and this for 200
http://www.newegg.com/Product/Produc...mus%20v%20gene
total 430 and no long term data on reliability with a 5% to 10% improvement in performance.
Mind you if you own Sandy now you can wait and see if oc'ing the ivb to 4.2 is a killer of the chip.
My guess is the ivb will proof less reliable then the sb will when you oc it.
BTW what is Intel's warranty policy on a chip that dies from oc.
(I know what it is and if need be Intel could be restrictive about rma'd chips)
This is speculation but sooner or later this will be true if not on a 22 nm chip then on a smaller chip. Or intel will just stop making k chips.
