Originally posted by: Mik3y
As you can see in the last pic, I concealed the optical drive bay using the meshed bezel that the case came with. Though this bezel was screwed into the case initially, that means there were metal straps that were attached to it. Well, its nothing a dremel cant cure. Since the bezel is meshed, using double sided tape directly is a no-no since it totally shows from the outside. What I had to do was use a strong glue stick and glue black card board to the inside part of the bezel. then i used double sided tape to tape the bezel to the drive bay. Vua-lah. It's a beaut. As for noise, as you can probably see from my sig, I've used all Zalman products to keep them quiet. And guess what! It's insanely quiet when tuned to the lowest speed settings. My CPU fan is the loudest piece in my case. Everything else and almost inaudible, aside from the HDD seeking.
