Originally posted by: elconejito
I have the CM 331, which is probably near identical. Nice case, I like it. Good airflow, reasonably toolless, solid construction, no jagged edges, cheap.
for this build i am building it for my brother and we are going halves on the cost.
and he kinda wants a bit more flashy case.
Raidmax Elite Series Gaming Case Sirius Mid tower - ATX - no power supply - brushed aluminum silver - USB/Audio << he likes this on it has 3 fan instead of 2 would this be better?
Also some else suggested to me i go with the phenom II because its where the future is at instead of sticking with the athlon 64
He suggested using this Cpu: AMD Phenom II X2 550 3.1Ghz 7MB Cache AM3 Black Ed and then saving money on the psu and going with the 450w corsair
He suggests that i change to a AMD 780G chipset but all the boards with this chipset are microATX what is the difference between microATX and ATX and would a motherboard such as:Gigabyte GA-MA78GM-US2H - Motherboard - micro ATX - AMD 780G - Socket AM2+ - UDMA133, Serial ATA-300 (RAID), eSATA - Gigabit Ethernet - FireWire - video - High Definition Audio (8-channel)
If i went with the phenon II processor would i need to get DDR3 ram? or change it to DDR2 1200MHz?
Yeah DDR2 1066 mHz will do. You really don't even need that speed, even 800 mHz stuff will do. Just make sure you get CAS4 stuff (4-4-4-12 timings) or 5-5-5-15 for 1066mHz. Most 1066mHz DDR2 is just OC'd 800 mHz RAM.
