montypythizzle
- Nov 12, 2006
- 3,698
- 0
- 71
Originally posted by: iRONic
No check today, Mike. Prolly tomano.
That's a fine finish job on the HT, mang. :thumbsup:
My component stand looks nicer :brokenheart:
Originally posted by: TastesLikeChicken
They are actually still far enough behind. They are located in the ceiling of a bay window. I was worried that their sound might get lost but a little tweaking of the Onkyo level calibration allowed for them to create a nice little spacial image. I was surprised how well those speakers sound, tbh. I didn't hold out much hope for them but they can really crank. Of course, ideally you'd want these speakers on the side instead, but the layout of their living area didn't allow for that configuration.Originally posted by: emfiend
This is a cool setup. I like the clean look of the wall the TV is mounted on.
About the placement of the rear speakers.... are they over the seating area or still far enough behind? How is the spatial representation of the sound with them mounted overhead? And do they have pointable tweeters?
I've got to deal with a similar arrangement where the only place it would make sense to mount the rears is overhead (in the ceiling). If necessary, I could mount them on long poles down to ear-level but in my case it would make for a cleaner install to leave them in the ceiling... But then I'm worried about hearing something as though it should be behind sounding like its over your head instead.
Edit: grammar
I can't wait to get the sub amp installed and get some serious thump going since the low end is prety subdued right now. It's really going to freak them out when they hear the sub kicking.
I'd estimate that the speakers are 4' to 5' behind the seating area. Probably closer to 4'.Originally posted by: emfiend
Edit: grammar
Can you give me an idea of distance behind the seating area they're placed? And probably the fact that the bay window is still lower than the actual ceiling helps alot.
Also, if you didnt do this already, putting in some batted insulation around the wall sub will help with controlling the spurious bay noise between the studs. It makes it sound very much more "punchy" (imho).
Cheers! :thumbsup:
There's nothing that you own now, nor is there anything you will ever own in your pathetic lifetime that will ever look nicer than what Mike has built, Montypyfucktardthizzle.Originally posted by: montypythizzle
My component stand looks nicer :brokenheart:Originally posted by: iRONic
kthxbi
They way I set their system up you won't actually see any of the components except when loading a DVD, so no need for a component stand. That's why I used the RF extender. If you look at the pic of the components you'll notice IR blasters mounted to each of them, except for the PS3. The RF extender converts RF signals from the Harmony 890 into IR signals sent through the blasters. That way the cabinet can stayed closed and nobody has to look at the components.Originally posted by: montypythizzle
No money in the budget for that. The monkeys will have to do the work from the outside.Originally posted by: montypythizzle
I want to get a Harmony remote, the 90 dollar one, the blue one. That is a good idea with the blasters and such. Now you just need a drop slot so they just drop the DVD in a slot and a cabinet monkey can do it for them!
