build a gaming rig
don't worry about a aftermarket hsf if you are not o/cing, the stock one will be just fine. also, go a x1900xt as it will be cheaper than 2x7900gts and also 1x7900gtx. 3800->4400? well the 4400 is the same speed as the 4200 except it has more cache, which you probably will not notice, so i would just get a 3800 and save some $$$$
don't be brand loyal, get what gives you the best bang for buck
if you can get the ram by tomorrow, i would get this - http://www.newegg.com/Product/Product.asp?Item=N82E16820145486
afaik you don't need 2xpci-16 for 2x7900gtxs, they don't use that much bandwidth and since you are not o/cing a aftermarket hsf is a total waste
Originally posted by: acegazda
amd and nv fanboy... WOW
And $2000 on a gaming computer with only one video card.
OP, I think you aught to look at exactly how much $$ you are throwing into just OC'ing that cpu (expensive motherboard, PSU, memory, aftermarket fans, etc). Gaming performance comes from the video card much more so than cpu.
OP, look at this...
Antec Performance One P180 Advanced Super Mid Tower Case Retail
$136.24
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140118
FSP Group (Fortron Source) FSP550-80GLC-R EPS12V 550W Power Supply 90 - 264V - Retail
$112.99
http://www.newegg.com/Product/Product.asp?Item=N82E16817104018
Asus P5ND2-SLI nForce4 SLI Intel Edition P4/Pentium D/Celeron 1066FSB LGA775 DDR2 ATX Motherboard
$92.99
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247012
Intel® Pentium® D Processor 940 3.2GHz, 800MHz FSB, Socket 775, 2x2MB Cache, Dual Core Retail
$217.90
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80852
Corsair VS2GBKIT667D2 2GB Kit DDR2-667 PC2-5300 Value Select Memory Retail
$150.80
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85016-47
Western Digital Caviar SE WD800JD 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
$45.99
http://www.newegg.com/Product/Product.asp?Item=N82E16822135106
Western Digital Caviar SE WD3200JD 320GB Serial ATA 7200RPM Hard Drive w/8MB Buffer
$113.50
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101252
NEC ND-3550A
$35.99
http://www.newegg.com/Product/Product.asp?Item=N82E16827152058
XFX PV-T71F-YDL9 GeForce 7900 GTX PCI Express 512MB DDR3 Video Card w/TV-Out & DVI Retail
$459.99
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=321061
$459.99
Creative Sound Blaster X-Fi XtremeMusic Sound Card Retail
$114.99
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=290236
Total Price: $1,941.37 (minus a ton of MIR's)
Everything above at STOCK speeds, can you honestly tell me that your system in the OP is going to be a faster gaming system than this? No.
More or less agree with bamacre, except no need for two hard drives in this case, especially when they're the same speed.
The 3800+ is going to beat the pentium 940 for gaming, (as would a 3000+), but the 3800 is $70 more ATM than the 940. AM2 3800+ could come down around $200 or even less in a month according to the buzz.
Dual 7900GTX cards in SLI would be an insanely good setup, but if you're running 1280x1024 it's a waste and you wouldn't notice much difference over a single card AFAIK. Plus you wouldn't be able to max out oblivion with either setup...
dual 7900gtxs would be good if you are running @ 1920x1080 or 1920x1440, but at 1280x1024 it is probably o/c
Oh, I didn't see what resolution he was gaming at. I assumed since he was spending $2K on a gaming system, he'd have a better monitor. Don't know what I was thinking. 😀
Even still...
Antec P180 $136.24
Fortron AX450-PN $51.50
Asus P5ND2-SLI $92.99
Pentium 940 $217.90
Corsair 2GB Kit DDR2-667 150.80
WD Caviar WD3200JD 320GB $113.50
NEC ND-3550A $35.99
BFG Tech Geforce 7900GTX $485.00
Total Price $1,283.92
$700 cheaper, and the difference between it and his $2K rig would be what, 5%, 10% at most? Pffft.
Aren't two 7900GTs faster than one 7900GTX? The 7900GT is $240 shipped AR right now. Two of them are the same price as the 7900GTX. You might have to get someone else to order the second 7900GT in order to qualify for two mail-in rebates. Or you could spend a little bit more and get the 7950GX2 for $560 shipped.
It might be overkill for 1280x1024, but if you're spending the same or only $80 more, then why not go fot it?
to be honest, i don't think i need another video card. sli/crossfire do not make any huge difference from single card but maybe a slight difference. so why should i bawl more money to spend on another card?
edit: and yes, it'll be an overkill for my 17" lcd monitor which its resolution is maxed at 1280x1024.
And why is AMD such a requirement? Why not go for a Conroe processor? But if you want to pay more money for an inferior processor just because it's AMD then that is fine with me.
come again, in a month or two.
