budget pc build
VirtualLarry
56,587
10,227
No, I really meant to include a single 4GB DIMM. If he gets a mATX board, that only has two DIMM slots, then he has no capability for expansion if he gets 2x2GB DIMMs. With the single 4GB DIMM, he can always add another one later on for 8GB total. Besides, dual-channel on AMD chipsets is only a 5-10% difference in performance, if even that.
airdata
4,987
The Athlon II 640 is a good choice IMO. It's a good choice for a cpu @ or under $100.
NEWYORKJETS000
1,063
there was a deal on slickdeals for 22" emachines for 100 bucks but it expired.. anyone know of another deal like this? i want to get 2 of them for dual monitors, closer to 200 the better.
mfenn
22,400
www.mfenn.com
OP, don't be silly about the GPU. There is really no reason to get a GTS 450 if a GTX 460 will fit into your budget. Along the same lines, don't be silly about the motherboard. Pick the least expensive one that has the features that you want.
For the record, I like fffblackmage's build, though I might swap the Hitachi for a Samsung F3 ($10 more).
zCypher
6,115
171
Just got my EVGA 460 which was about $150 after rebate
I'm looking for some games to play now, but so far dabbled in the older ones (CSS, Mass Effect, Bioshock) and it's a massive upgrade from the 7600GT I had. Couldn't be happier with my purchase so far.
No idea how it compares to the GTS450 though.
I agree with the PSU comments - I'm using an Antec and it's been good to me. Only heard great things about XFX and Seasonic over and over, too. fffblackmage and mfenn have helped me out a lot and are a great resource around here, so consider their advice!
and good luck :D
NEWYORKJETS000
1,063
i agree they have helped a bunch.. maybe the prices will come down on some of these parts in the next 2 weeks.
NEWYORKJETS000
1,063
i think im going to hold off on the video card now, whats board has the best onboard gpu right now? i seen one with the ati radeon hd 4250 build-in 128MB DDR3 1333 sideport memory.
fffblackmage
2,548
Well, the "best" IGP for ATI is probably the HD4290 found on the 890GX chipset, but it's basically an overclocked HD4200.
Sideport memory has a pretty insignificant impact. Maybe it's because 128MB is just too little to rely entirely on it. It doesn't hurt to have it though, unless you have to pay extra for it.
mfenn
22,400
www.mfenn.com
You're not going to be able to game worth crap on an IGP anyway, so it's not worth paying extra for a "fancy" one. Just get the 880GM-LE recommended on the first page.
