Budget gaming/everything system
Denithor
6,298
23
Well, it looks like you have this thing nearly wrapped up, but I thought I'd throw in my 2 bits.
I typically avoid OCZ memory after having 2x1GB DDR2-667 Gold sticks fail to boot in 4 out of 6 motherboards I have tried it (and one of those only worked after a memory-specific BIOS update using cheap Kingston memory to boot for the flash). Instead, if you haven't already ordered, go for the Kingston N5 for $43 shipped.
One of the best values in motherboard I have found is the DFI BLOOD IRON P35-T2RL for $115 (P35/ICH9R chipset, DFI is known for packing in the most OC friendly BIOS options possible).
Cheap aftermarket cooler ($2 after MIR):
COOLER MASTER RR-CCH-L9U1-GP 92mm Hyper TX2 CPU Cooler - Retail
taltamir
13,576
OCZ has been having very serious compatibility problems with their DDR2. Really bad ones. Thats why you find them so cheap, and with rebates. And why it failed on 4 out of 6 mobos for you.
I would stay away from them for DDR2.
VirtualLarry
56,587
10,225
I've had good luck with SuperTalent DDR2 RAM. The DDR2-667 5-5-5-15 RAM, will, with 2.0v, run at DDR2-800 4-4-4-12.
Tempered81
6,374
Mr r, i'd downgrade that 100 dollar 700watt ocz power supply to a 50 or 60 dollar 500watt antec or rosewill
I also run supertalent ddr2 800, and have heard bad news about the ocz ram. I bet you wont have a problem with it and 41 bucks is a good deal
glad to hear you upgraded to the 8800gt 512, thats what im using, and you're about to have 1 screaming machine.
cod1 2 3 & 4 will run with maxed out graphics at the highest resolutions. It looks like real life!
